Broken BX turnbuckle
/ Broken BX turnbuckle #1
Singlecoil
Eatonville, Washington
Kubota BX-24D Cub Cadet LT42e
I noticed that my box scraper had a little too much play side to side and was too slow getting around to tightening the turnbuckles I guess. I was working it pretty hard. Upon inspection, the original welds didn't seem to be very beefy, but then I'm not a welder.
The good news is I took it to a welding shop and they put 4 new welds on it with an arc-welder for no charge.
Made my day.
/ Broken BX turnbuckle #2
Hated those turnbuckles from the get go... mine have been hanging on the garage wall for years... just keep a drawbar on the tractor in case I need to move a trailer... BUT, I never 3 point anything on the orange tractor. I use the Ford for rear implements.
mark
/ Broken BX turnbuckle #3
Were you making turns with the box blade engaged to the ground? Just curious as to how it could get broken like that.
/ Broken BX turnbuckle #4
I broke both of mine the same way and welded them both back. It seems to happen if you have too much slack in them. I keep them snugged up now and have not broke one since.
Come to think of it, I was. I've been carving out a walking trail and using the scarifier teeth to pull up some pretty good sized roots as well.
I think it was mainly a too much slack issue.
/ Broken BX turnbuckle #6
I broke my recently while pulling my XB Rototiller. Thought I had the turnbuckles fairly tight at the time. Maybe doing curves with the tiller was the issue. The manual says straight line only but............ curves are nicer than a ragged edge. Mine cost $10 at local weld shop. Their minimum charge. Not as friendly as mentioned in some of the replies. Took all of 1 minute to repair.
/ Broken BX turnbuckle #7
Get used to it. I have broken a half dozen in 450 hours, always while blading. Spares are actually pretty cheap at TractorSmart.
Russell in Texas
/ Broken BX turnbuckle #9
/ Broken BX turnbuckle #10
I'll second PaulZ's suggestion. I did it on my BX and it's SOOOOO much better! No tools. I also replaced my solid lifting rod with an adjustable one so that I can get more lift height. Another useful mod for older-style BX's.
/ Broken BX turnbuckle #11
That looks like a poor weld. When you get is re-welded, they may want to beef up the others.
(8) Rachet Straps (A64127)
(8) Rachet Straps...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
Spirit Electric Tricycle (A64127)
Spirit Electric...
Glenco 20' Field Cultivator (A66408)
Glenco 20' Field...
20 Ton Hydraulic Bottle Jack (A64127)
20 Ton Hydraulic...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
