Broken Branson
/ Broken Branson #11
HI, I had the same problem recently. What a pain. At the steering valve it's a 1/4" British Standard Straight pipe thread. A local hydraulic hose company came up with an adapter that went from that to a standard male 1/4' and from that they used a standard 45* swivel fitting and then by the front axle they used a Japanese fitting. I made the hoses as Branson did with a junction in the middle but I wouldn't if I did it again.
I tried to get hoses from Branson but they sent the wrong ones and it seems like the steerings hoses changed several times and it would appear they have a hard time sorting out which ones fit which tractors. So if you go that route take your old hoses with you.
Brad
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
17307 (A55853)
17307 (A55853)
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
2011 Toro Multi Pro 1250 Gas Sprayer Cart (A59228)
2011 Toro Multi...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
Cushman Cart (A59231)
