Broken Branson SL00 Joystick
/ Broken Branson SL00 Joystick #1
Hiit-Man
Branson 2400h
HI,
New to the forum. I have a 6 year old Branson 2400h with a SL00 loader. I have had 2 joystick plates break on me in the last 6 years. It has broken where it is fastened to the plate. I have to buy the whole assembly not just the plate. Cost is over $300. Anyone else have this issue?
Any way to strengthen it? I called a local tractor supply, they said that their parts vendor shows no inventory. He ordered it, but doesn't know if they have it to ship. I'm located in the Spokane area.
/ Broken Branson SL00 Joystick #2
Can You Take some pictures and to show the parts that are broke?
/ Broken Branson SL00 Joystick #4
Are the pivot points well lubed on the joystick? Did any of the mounting bolts work loose? Did you feel excessive force was required to move the joystick one direction vs the other?
I do not have original valve so can’t comment on their strenght.
this is the plate that breaks
/ Broken Branson SL00 Joystick #6
Next time, you may want to post this type of thing in the Branson section. There are some helpful folks over there.
@Asteral usually has inside info that may be of use. There is a big dealership down here in North Texas that may have some options for you.
Sorry about that. I didn't know there was a Branson section. I know it's not a popular brand. Can this post be moved to that section?
/ Broken Branson SL00 Joystick #8
Looks like pivot bolt breaks out of the cast material. Is that function curl dump or lift lower. If lift lower is your detent difficult to engage and release?
I don't know which function it is. The tractor is my wife's, I don't operate it much.
/ Broken Branson SL00 Joystick #10
Well tell her to quit operating it when she is mad at you 😂😂
/ Broken Branson SL00 Joystick #11
Take it to a machine shop or good fabrication shop and have them make you one. They are not that difficult to make and will last longer than the original.
/ Broken Branson SL00 Joystick #12
One option since the price of a new one is High is to take it to a machine shop and have them build you one out of steel. Because it is a 90 degree and has bolt in holes they should be able to duplicate it fairly easy out of some good steel with a mill. Might take a couple hours probably less and cost might be even less than 300$
/ Broken Branson SL00 Joystick #13
K5lwq Great minds think alike 😆 opps your comment did not show up until after I posted mine lol then it showed you were first. sorry
/ Broken Branson SL00 Joystick #14
No worries. I suggest the same thing not to long ago to a guy with the same issue. He decided to make his own and worked just fine. It does not have to be fancy.
/ Broken Branson SL00 Joystick #15
I found the thread I was talking about. A little different design but works the same way. You can see what he came up with that is working.
Thanks for the suggestion. I'm not handy that way, but I will try to find a machine shop that can manufacture it.
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
2017 Genie GTH-636 (A62177)
2017 Genie GTH-636...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
3PT. PTO DRIVEN SPRAYER (A62131)
3PT. PTO DRIVEN...
