Broken bolt on Landpride mower blade
/ Broken bolt on Landpride mower blade #1
rickmacheske
Catharpin, VA
Kubota L3400 HST
Well...I had a blade fall off of my 6' Landpride finish mower. Does anyone know where I can get a new bolt? Also, I remember taken the blades off to sharpen them was very difficult. How am I going to get the broken bolt out?
Thanks,
Rick
/ Broken bolt on Landpride mower blade #2
Thanks,
Rick
This is the bolt that holds the blade on, correct?
Pull one of the other bolts. If it's a standard bolt, take it to your local hardware store for a replacement. If nonstandard, you may have to order one.
Per the Landpride website, your bolt should be ½-20 x 2" long, grade 8. Since I don't know what model you have, I just picked one of the finishing mower parts manuals.
Now, you wrote the bolt broke off. Did this happen when you were installing the blade? Did it break flush with the spindle? If any of the bolt is still sticking out, you may be able to get vicegrips or a pipe wrench on it after you've soaked it in penetrating oil for a few hours. If you have an acetylene rig or MAPP gas torch, you can try heating the spindle, but this might damage a spindle bearing.
If the bolt is broken flush to the surface or down inside, you'll need a bolt extractor (aka Easy Out). Bolt extractors are easy to use. You want to ensure you get one of the proper size for the bolt you want to remove.
Basically, you want to drill a hole through the length of the bolt. The diameter of the drill should be a bit larger then the minimum diameter of the extractor, but smaller then the maximum diameter of the extractor.
Once you've drilled the hole as straight through the bolt as you can (remember to use goggles!), tap the extractor into the hole. You'll notice the flutes on the extractor are left hand which is the opposite of the bolt thread (right hand). There are flats for a wrench on the extractor. Get a good purchase on the flats and keep tapping the extractor as you try to back the bolt out. Hopefully, the extractor will cut into the bolt as you're tapping and unscrew the bolt.
It's actually easier to do then reading it. It'll take longer to get all the tools together and position the mower safely. That mower weighs several hundred pounds. If it falls on you, you will be severely injured or killed. Do not just raise it on the 3PH and work under it. My mower isn't that heavy (about 450-500 pounds). Whenever I'm pulling the blades, I chain it to the bucket hooks and position it so it would fall away from me (if it fell). I'd consider rolling it all the way over if I had to drill out a bolt. If you do this, drain the gearbox. Otherwise, the gear oil will drain out of the vent holes.
Drilling the hole is the toughest part. It would be advisable to drill a smaller diameter hole through the bolt first. You may not have to drill the hole length of the bolt, but you'll want that extractor well seated in the hole before you try to back the screw out.
Once you get the screw out, I suggest you look for the torque value per the owner's manual of your mower. Torquing to the correct spec not only ensures the bolt is properly tightened, it ensures the bolt is not overly tightened which may have been why it failed. I use an anti-seize compound to prevent the bolt from rusting in place.
If you're not sure of your ability to do this, take it to the dealer or a mechanic.
Good luck!
Thanks Roy. I'll give it a shot. The bolt broke flush. I don't think it was overtorqued since I always use a torque wrench when I install them. Guess it will give me a chance to sharpen the blades for the season :)
/ Broken bolt on Landpride mower blade #4
I was at TSC when they were giving away the foam blocks that they set trailers and stuff on, I used them to set my 6' brush hog on when I worked on it, Plus jack stands of coarse. They are 12" by 12" and about 16" long wrapped in plastic. They made it nice even when it started to rain and then snow.
/ Broken bolt on Landpride mower blade #5
Rick, try unscrewing the bolt using a hammer and a small cold chisel. I had a grade 8 break off on the front of my Ford 302 crankshaft. It holds the harmonic balancer in place. Luckily I caught it in time and no damage was done. My brother used the hammer and cold chisel to tap on the bolt to the extent we could unscrew with fingers. Needless to say I was lucky. I was not so lucky the first time that happened. Can you say new crank?
/ Broken bolt on Landpride mower blade #6
Last poster gave great advice, If it is broken flush or even a little recessed substitute a GOOD center punch for the chisle. first hit, positioned as far to the outside as possible with out damaging the female threads at 90degrees to bolt. then tap in at as low an angle as you can with out having the punch destroy your hole. Its amazing how many bolts will walk right out once the heads are poped off.
Another tried and true way is to cut a flat tip screwdriver slot in the bolt and use a hand impact driver to get it out. I have even drilled a hole and pounded a torx bit into the dead center of the bolt and used hand or air impacts.
Some people say necessity is the mother of invention
My old grandpapy used to say "Aint this a Mother....."
/ Broken bolt on Landpride mower blade #7
If the bolt broke off flush with the spindle it will be very hard to extract. I don't know about applying heat, bearings and seals may suffer. Consider removing the complete spindle from the mowing deck and taking to a machine shop and have them drill and extract the broken bolt.
That seems to make sense. I think I'll remove the assembly and do it in my shop instead of on the mower if I can't get it out quickly.
Great advice!
The center punch worked great! The bolt backed right out with very little resistance. I found the "bolt washer". The local dealer has the washer and bolt in stock so it looks like I can finish mowing tomorrow :( Just when I was having so much fun running water pipe instead, lol.
/ Broken bolt on Landpride mower blade #10
Great news!
Glad it worked out for you!
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59909)
2015 FREIGHTLINER...
Paladin Dirt Sifter (A61166)
Paladin Dirt...
Pallet of Forklift Safety Basket (A61567)
Pallet of Forklift...
2016 Jeep Compass AWD SUV (A61569)
2016 Jeep Compass...
LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A60352)
LandHonor...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
