Broken again, loosing faith
   / Broken again, loosing faith #231
I hear you on that, makes perfect sense, but why the relief valve would not pass enough fluid to protect the pump from over heating and damage is the point I'm mystified about. Are the respective parts not matched properly?
Got me on that question. That one is beyond my level of knowledge.
   / Broken again, loosing faith #234
So what there saying is if you knock the lever to A or B with nothing hooked up you will dead head the system? Why would the main preasure relief valve work? It should be part of the system.
If any of you have a service book look to 10-10 last paragraph.
the hydraulic preasure of implement line is controlled at 2683 PSI by the main relief valve that is installed in the joystick valve Therefore, when the pressure in the circut increases over the relief pressure due to the overload for the operation of the joystick, auxiliary double acting valve and lifting cylinder, the relief valve is open to protect the circut.
Sooo, how can it deadhead????
   / Broken again, loosing faith #235
Its just the way it is. Whether its common to other tractors is somewhat irrelevant. Its standard on the Kiotis of DK series. Use a loop, or remove the detents, or suffer the consequences when nothing is hooked into the remote circuit.
   / Broken again, loosing faith #236
Sounds like the relief is undersized, or the cooling system is undersized and cannot handle the heat created by the relief valve for more than a couple of minutes.
Aaron Z
   / Broken again, loosing faith #237
Its NOT the joystick we're talking about! Its the A/B circuit of one of the two possible PAIRS of rear remotes. The second pair, (C/D)comes from Kioti WITHOUT a detent in the valve's body.
The relief valve doesn't enter into the equation because there is no flow. With the lever for A/B circuit in either A OR B position, therefore detented, the pump is pumping against a wall. NO FLOW. Pump gets no return flow to it and thus burns out; unlike when it gets flow from pump back through pump with the loop in the circuit completing the circle of flow.
One last time: Use a loop, or don't, and burn out a pump. OR remove the detents. Choice is operator's.
Seems this thread is plenty hijacked now. Let's end this endless discussion of something pretty simple to grasp- OK?:confused2::thumbsup:
   / Broken again, loosing faith #238
Aaron Z
Ok look at it this way, Lets say this is a Kubota, and disregard the rear remote with the detent, lets say we operate the main lift valve on the FEL, it goes all the way up and we just sit there and hold the valve back and keep on holding it. The system goes into relief, and we notice the drag on the motor and the whine noise, but we just keep on holding it, How long will the pump on the Kubota last? Developing full pressure into the deadheaded fully extended cylinders. This is the same scenario we are talking about here with the rear remote with the control valve locked into detent and full pressure developed into the not moving connector, with the relief valve trying to relieve the pressure. I don't know how long the Kubota will last, and I don't know how long the Kioti will last with the detented valve stuck applying pressure into the dead ended connector. But with my Kubota scenario you just would not sit there with your hand on the joystick until something breaks now would you? But with the detented Kioti valve you could accidentally activate it into detent and not notice the drag on the engine and the change in pump noise, and just bush hog away for hours until something breaks. right? So smart dealers either remove the detent balls, or supply a loop hose to prevent the load on the pump from developing. I do not see this as a big deal either way. If you remove the balls, you just use a bungee cord after the log splitter is hooked up to hold the valve operated. Or if you retained the detent balls, then you should be protected against accidental operation by the loop hose. Another scenario, would you put your hydrostat equipped tractor in HI range and push up against a big tree and put the hydro into relief and just sit there with the hydro relieving and heating up the fluid, and just hold the pedal to the floor ?? of course you would not do that. Something is liable to give up after a while, but the point is the detented control valve for the rear remotes can, and has been accidentally operated by someone, and left that way so dealers are apprehensive about them.
James K0UA
My 2 cents is if you do or may use something that requires detentes, leave them alone and install a loop. If you know you'll never use something that requires a constant flow, remove them. It's going to come down to a personal choice based on how you use your tractor. I personally like them, I'm not to worried about accidentally hitting the valve and am confident I'd recognize the signs if I did. I will still take the advice to install a loop, it just may not be first thing Monday morning.
   / Broken again, loosing faith #240
Agreed, pretty much the way I feel about them. I was never planning on a backhoe or Log splitter, and figured a bungee would work fine If I did, and my intended uses for the rear remote would not require a detent and the dealer really wanted to remove them so I let him.. I have them If I change my mind.
James K0UA
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2014 Mercedes GL550 AWD SUV (A56859)
2014 Mercedes...
2018 Chevy Silverado 1500 4X4 (A56435)
2018 Chevy...
Willmar Wrangler 4500 (A56435)
Willmar Wrangler...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
SAFETY BOX FOR FORKLIFT (A52708)
SAFETY BOX FOR...
