Broke off hydraulic fitting in ram.
   / Broke off hydraulic fitting in ram. #1
kuby
Alberta, Canada
L 245DT
I was messing around pushing trees with my bota and broke off the street elbow on the tilt cyl. I tried everything to get the busted off piece out but with easy outs and even heat but no luck. This is an older tractor with old cyl. and was wondering if I could just weld a elbow on or should I drill out the nipple and re thread the nipple one size larger?? Would a welded on elbow hold the preasure?
   / Broke off hydraulic fitting in ram. #2
Did you try to turn the stub with a chisel and a hammer? You can get a surprising amount of torque going without the expansion that you sometimes get with an easy out.
I can't help you with the other questions. /forums/images/graemlins/confused.gif
   / Broke off hydraulic fitting in ram. #3
Are the fittings brass or steel? Brass can be brazed steel can be welded. I don't believe that you will get a good solid connection doing either of these.
I don't think drilling out and retapping to the next larger size will work either. You are probably 3/8 NPT now and going to 1/2 is a rather large jump.
I recommend that you remove the cylinder from the tractor and take it to a local hydraulic repair shop. They can probably help you get it done right and safe.
   / Broke off hydraulic fitting in ram. #4
What I have done in the past is > Take a Dramel with a thin cut off disc, cut down the center of the fitting about an 1/8 to 1/4". Then take a punch and put it on on the O.D. of the fitting to one side of the cut. It will usually split. Don't cut any more than I said or your new fitting might not seal if it is a pipe thread.
   / Broke off hydraulic fitting in ram. #5
Get you a left hand drill bit a little larger than the hole in the fitting and drill it out. Allot of times the bit will loosen the damaged fitting and the drill's power will screw it right out.
Fun eh!!
   / Broke off hydraulic fitting in ram. #6
With all the drilling and cutting mentioned, remember that you also have to figure out how to get all the metal chips out of the hole also. I would just bite the bullet and have a machine shop do this for you. They have the tools and the know how and it will be cheap. Consider the cost of the chips doing damage to the cylinder or the pump by comparison. Drive a little..... save a lot. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
flooring (A53424)
flooring (A53424)
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2014 KENWORTH T800 KILL TRUCK & TRAILER (INOPERABLE) (A53843)
2014 KENWORTH T800...
