Loader : Broke my FEL Valve?! (possibly?).
   / : Broke my FEL Valve?! (possibly?). #11
Can you get relief pressure on the cyl you are trying to operate?
If yes, then the cyl are OK.
In neutral, the cyl are locked.
If you had a gage installed, you could monitor and trouble shoot the hyd system.
If your bucket folds when all levers are in neutral, then I would suspect the seals.
Is the valve spool returning back to neutral.
There are spool centering springs and a nut under the cap on the bottom of the valve. Remove and check. Move the lever fully in and out when checking.
Are you holding any lever when back dragging, or do you put the lift in float and back drag?
Not sure- read down....
OK.
Understood.
OK, which ones, cylinders, valve body which controls the cyls?
Not sure what a valve spool is exactly; is it the little thumb sized canister bolted to the outside of the valve body?
I'll need more guidance as to where to do this, when we get to that juncture.
I lever the bucket edge perpendicular to ground. I can then push the lever down and the front wheels will lift off the ground. With the wheels on the ground, not levering in any direction, I can initiate back dragging, but the bucket edge folds forward, and does NOT back drag any amount of material.
I disconnected the QD under the right side floor pan, then inspected them, cleaned them and reassembled. Tried it out, no better results. I then ran engine 'till warm and removed both HST and hydraulic filters. I kept all fluid from both, and then installed and ran, and leak checked both filters. No change of symptoms in the back drag efforts.
I don't know if what I just wrote tells you anything about what is happening, but I'm mostly clueless as to what is causing the symptoms. All else I can say is even with a 72" bucket attached I cannot get the regen/fast dump to function- it will still pull the bucket up toward the tractor's front end INSTEAD of fast dumping, even loaded full of topsoil. In fact, I don't think regen has ever worked; I don't remember ever seeing the bucket dump fast, and if I had I likely would have remembered it and learned how to repeat it....
Thanks, J J, hope what I wrote makes some sense to you....
   / : Broke my FEL Valve?! (possibly?). #13
CM, did you disconnect, check and reconnect all four QD's under the floorboard? Thinking that if one can get bumped loose then maybe others did as well. According to the loader manual, the two QD's innermost (red and white) deal with "tilt" and the two outermost (yellow and green) are for lift. Your problem seems to be in the tilt circuit, since there is no such thing as a coincidence...
I've checked all by making sure I cannot pull any out of their female QD. The one that came loose is the outermost one, the one exposed the most to under chassis traffic by gremlins, rocks, sticks, etc. It is yellow colored one. The two innermost ones are where my diverter connects into the valve body below floorpan and feeds the diverter valve body. There are no leaks anywhere on my tractor, from any fluid holding mechanism; engine, hydraulics, coolant, etc. I check it everyday for spots of liquid on the shop floor.
   / : Broke my FEL Valve?! (possibly?). #15
Interesting, my manual says the outermost one is green. Red is innermost, then white, yellow and finally green. Just checked the loader and it confirms the manual is correct.
I'm not sure the color matching is important as that each hose corresponds to each valve QD location. My prior Kioti also had mixed up boots/plugs for the hoses/valve's QDs, and when I tried to match up the same colors it made something work backwards. I think there must be a colorchallenged or dsylexic mechanic in my dealer's shop?!:confused2::eek:
   / : Broke my FEL Valve?! (possibly?). #17
CM, Is this the first time back dragging since diverter valve install? If your diverter valve is plumbed into the same hoses as the curl cylinders, could the diverter valve be creating an oil path around the FEL control valve? Could the diverter valve spool be hanging up and not closing all the way? Just my 2 cents worth.
Seacap04,
No, the diverter valve has been in place for about a year, maybe more? IIRC.
How do I figure out what is happening?
I have been digging out huge amounts of packed topsoil at my flip property. I can cut with the bucket edge going forward. I can push the edge into the hillside and curl back once I reach relief sounds and lift a full bucket no problem. When I try to back drag the bucket edge immediately gives way and drags no material. I can pull the bucket all the way back against the loader arm stops and stick the bucket edge into the soil and attempt to drag back, with no resistance from the bucket...
What you said about the possible oil 'path' around the FEL valve; assuming that is the case for the moment, what to do to verify and then fix it? I'm not aware how to determine if the diverter valve spool is hanging up, and if it is what to do to stop it.
   / : Broke my FEL Valve?! (possibly?). #19
CM, I do not know how your diverter valve is plumbed. My original thought was instead of a "closed" system which you would have with FEL in the neutral position oil could not move unless a cylinder seal was leaking. My thought was that if the diverter valve was plumbed into the curl circuit and hanging up you could create an "open" circuit where oil could move it either direction. However, if this was true, you would not be able to dig in packed soil without issues. Also if the FEL valve had issues, you could not dig packed dirt with out the bucket being uncontrollable. I need to reread your posts for another clue. The question as I see it, every thing is normal, except down pressure on curl.
Seems accurate. Let me ask you this: if you go to regen/fast dump with a full bucket of whatever, does you bucket dump faster than it does in regular dump? And in regular dump does it dump slower than when curling the bucket back with the same load? When I've been working her in the dirt and stop to take a break, I notice the larger cylinders, underside of FEL arms, are hot. Not so hot that I can't put my hand on them but hot nonetheless. I suspect this is normal, but don't know how hot would be too hot - indicating a problem?
If I could figure out what to take apart and clean, or what to replace, I'd do it- but nothing seems to jump out at me as to what to look for. If there was a symptom tree I could follow it to it's logical conclusion.
I need to be able to use the backdrag ability to smooth out the landscape.
I re-read your last sentence; isn't down pressure for backdragging the opposite of curling position on the FEL lever? Wouldn't the bucket curl UP and not down? I'm confused....
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
3410 (A47477)
3410 (A47477)
BED FROM 2024 FORD F250 SUPER DUTY (A58018)
BED FROM 2024 FORD...
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
