broke Hyd nipple, what part nr?
   / broke Hyd nipple, what part nr? #1
RexB
Northwest WA.
CK30HST TLB, JD 350 'dozer
I broke one of the four nipples that screws into the auxilliary hydraulic joy stick manifold (under the HST pedal). It's for a hose to the front bucket. I'm looking now, but does anyone know the part# for this? A 3/4" wrench took it off...
   / broke Hyd nipple, what part nr? #2
Working in the brush were we? Come on, we have to get the story. I have managed to push the entire FEL hydraulic control unit up towards the floor board, managed to bend the high pressure metal line that runs under that valve cluster, and also knocked the fittings loose at the place where yours broke all from brush poking up at the wrong time.
Luckily never broke one though. RedRocker's skid plate has a special wing just to prevent this sort of thing.
   / broke Hyd nipple, what part nr? #3
That's actually a common fluid coupling part. Go to any tractor supply store, dealer, or a good hardware store (you know, the one with squeaky wooden floors) and pick up one. If you get desperate, you can use a brass one. Oh ny God, the reaction that statement with generate. It could kill you, the hydraulic oil (they will spell it "hydrolic") will get contaminated, the threads ("treads") with get stripped, the flow rate will droop, and the tractor will look funny with a brass part in it. Yeah, so what?? You're runnin' ain't ya?
Go ahead, order the $200 part from Japan. Our balance of payments is falling behind....
One more thang, If you was really a tractor man, you'd go out and buy that $2500 Miller Syncrowave TIG and put it all back together, you know, OE.
   / broke Hyd nipple, what part nr? #4
Kioti part # 6004-0101
Description ..ADAPTER, 1/2-20 UNF 9/16 - 18 o-ring
A new one is about $3.50
ROTFLMAO, you got it. In the brush, got poked, and a geyser blew out the front. I can think of better ways to oil a trail. Will use brass no problemo to get back to work and replace it later (right).
Thanks Monsieur Wallace for the steel part #. I'm in the woods, will drive 25mi to hardware store in a few hours and look -- it's possible that my little town won't have that nipplewhatchamacallit in steel...
HAA the TIG would be realreal nice, but first a plasma cutter. And before that a grapple. And before that a .... you know how it goes :~)
While I'm DAP, a temp skid plate goes under that manifold. This winter i'll fab the real deal courtesy of RedRocker's photos.
To make a short story... as the trail was developing I figured that I'd better throw off the logs/sticks we kept back-and-forthing over before one of them flipped up and bit me. As I was stopping to do it, POP goes the geyser. My usual timing. Oh yeah, bent that new bigass tie rod too.
I need an online supplier for the hydraulic adapter and similar parts:
The last two days I went to 5 hardware stores, 2 heavy equipment rental outfits and the best building supply place around here and only found a brass fitting. I'm up and running again, that's the important thing, but need to find an online supplier and I will order a stock of steel adapters. Cuz this CK30 is a 'keeper' and I can see it won't be the last time some parts get broke by logs, roots, whatever. Just SOP.
I've checked 5 online parts places rec'd by members here and Googled for the part# and no listings. One catalog i did find was a list for a partsupply counterman that i couldn't really understand if i'm getting the right part or not, no pictures (i'm spoiled), so who has a good online catalog for this stuff?
Or do I have to call my dealer 500miles away, or the closest dealer 90 miles away, and ask? Wallace i checked your site and don't see a catalog for these parts, am i blind?
   / broke Hyd nipple, what part nr? #7
I've mail ordered parts from some of the dealers met here at TBN and they arrived at my door in very short time. I wouldn't hesitate to do that before driving 90 miles. I think wallace was the first one to give you that part number, I would reward him with the order.
I have also found that by ordering an extra replacement part you are almost guaranteed to extend the time until the next breakage. I buy the hydro filter in pairs since it is so very easy to smash or break off. Between the hydro filter and the tie rod, I check the belly of the machine pretty often.
Oh and also keep an eye on those inboard steering ram grease zercs. They hang down there too.
I've checked 5 online parts places rec'd by members here and Googled for the part# and no listings...so who has a good online catalog for this stuff?
...Wallace i checked your site and don't see a catalog for these parts, am i blind?
I'd like to Highbeam but don't see the catalog on his dealer site, or any other either. I'm blind, so what is the link to the online catalog, or do I need to phone order?
That's funny; "by ordering an extra replacement part you are almost guaranteed to extend the time until the next breakage." I should be so lucky LOL.
We.finished plowing dirt and hardpan that put a strain on the FEL and this brass hyd adapter, it seeps but no leeks Haa... i luv 'dis CK30.
I'll check those grease zerks at first light because i was back&forthing over stumps 'n logs. I'll order a few extra zerks too when I find the right size/thread....i know it's been posted somewhere but that post was bouncing between many sizes of zerks and i never could decide which are the right zerks.
Not enough coffee i guess...
   / broke Hyd nipple, what part nr? #9
RexB
There are no catalogs...
I just went to our parts break down and got you the part#
If you would like just drop me a pm with your address and I will be sure to get you a couple out..
We take MC..VISA...and DISCOVER
We ship parts everyday.
I can also provide any and every one with online part breakdowns if needed.
Rick
Just got off the phone with Rick W and the parts are on the way -- ordered a few extra of this 'n that cuz ya' never know...
1989 CAT D30D Articulating Dump Truck (A59213)
1989 CAT D30D...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Year: 2008 Make: GMC Model: Sierra Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A56858)
Year: 2008 Make...
24in excavator tooth bucket (A56435)
24in excavator...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
