Charlie_Iliff
Veteran Member
- Joined
- Jun 13, 2001
- Messages
- 1,896
- Location
- Arnold, MD
- Tractor
- Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
Did a bunch of mulch moving, some garden tilling, some gravel spreading and some mowing over the weekend. All worked great, except:...
A couple of wires (starter) broke and had to be put back in the main junction box. I don't know if they were stressed at installation or something poked them when the cover was off. I've had a little trouble keeping it on.
A finish mower blade broke. Fortunately, this is the finish mower set which bolts on the stump jumper in the 6 foot rough-cut deck. Each spindle has four short blades welded to a heavy ring that bolts to the stump jumper in place of the hinged rough-cut blades. This isn't the configuration of any other finish mower, I don't think, so shouldn't be a problem for anyone not using this particular combination. I had only mowed about an hour and a half, when I managed to get the blade into a small hump of dirt and it broke. The rough-cut blades have lived through rocks, wire, stumps, etc. with nothing but a dent or two, but the finish blade ripped off the ring. I'm talking to Terry Estep at Power Trac about replacement, and maybe a different configuration.
Before it busted, the finish setup did a pretty nice smooth job. It wasn't golf course quality, but I was cutting 2 week growth. The finish blades blew out a lot more dust than the rough cut, and heated the engine more.
Searches on this board, Lawnsite and some others show a wide range of theories about cutter blade shape, and variations in preferences for different deck designs. Yet another area for research and experimentation. Anyone have a suggestion for the best airfoil shape for hinged 6 inch blades on stump jumpers under a 6 foot deck?
