Brocken woods blade
/ Brocken woods blade #1
edt
So. N.H
long 300dtc
Hi all a couple of questions for ya 1st has anybody had a problem with breaking of the bolt on a rear blade from woods it's a rb 72 the bolt broke while scrapping soil it broke off at the welded on nut # 2 will a screw extrtactor remove the section broken of or will i need to have it cut off and new one welded on the blade it's only 1 year old and i'm not that hard on the usage thanks all
EDT
/ Brocken woods blade #2
Broken bolts are always a pita. If I tell you it will work it won't. If I tell you it will not, it will. So, try it. Use some PB Blaster to soak up the threads ahead of time. Maybe some heat from a torch on the outer part of the nut will help.
/ Brocken woods blade #3
I don't know if u have room but take a smaller nut and put on top off broken stud and weld inside down to top off stud.
then use wrench to back out.
Thanks all just too let you no i removed the old brocken bolt with ease with a screw extractor worked great let it soak for two days in sok lubricating spray
Thanks edt
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
7888SFL (A61567)
7888SFL (A61567)
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
