Brocken woods blade
   / Brocken woods blade #1
edt
So. N.H
long 300dtc
Hi all a couple of questions for ya 1st has anybody had a problem with breaking of the bolt on a rear blade from woods it's a rb 72 the bolt broke while scrapping soil it broke off at the welded on nut # 2 will a screw extrtactor remove the section broken of or will i need to have it cut off and new one welded on the blade it's only 1 year old and i'm not that hard on the usage thanks all
EDT
   / Brocken woods blade #2
Broken bolts are always a pita. If I tell you it will work it won't. If I tell you it will not, it will. So, try it. Use some PB Blaster to soak up the threads ahead of time. Maybe some heat from a torch on the outer part of the nut will help.
   / Brocken woods blade #3
I don't know if u have room but take a smaller nut and put on top off broken stud and weld inside down to top off stud.
then use wrench to back out.
Thanks all just too let you no i removed the old brocken bolt with ease with a screw extractor worked great let it soak for two days in sok lubricating spray
Thanks edt
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
Van Trailer (A53117)
