Bringing old gravel to the surface
   / Bringing old gravel to the surface #1
Mike058
Key Peninsula, Wa
Kioti CK3510SE
Our turnaround is bare of gravel in some places. I'd like to bring old gravel to the top. I have a 35HP tractor, loaded tires and a landscape rake. One question is how deep do I eventually set the tines? And should I make a couple of passes shallower and then lower the rake, or just drop it down as far as my tractor can pull it? I don't want to move any gravel around, so I was planning on removing every other tine. Thanks.
   / Bringing old gravel to the surface #2
Start with a little trial and error, you will have to experiment with your conditions to see what works for you
   / Bringing old gravel to the surface #4
A landscape rake will not dig in enough to bring gravel up. You could do it with 1 or 2 rippers in a heavy box blade and even that is slow going. Very short top link so it's aggressively cutting.
I also, agree above that if the gravel is packed already, I would just add more. (Unless you know there is already 8" or more of gravel on top of a good road base).
   / Bringing old gravel to the surface #5
I suggest you purchase some gauge wheels. Those make the job much easier.
   / Bringing old gravel to the surface #6
Ground, rock, water all vary with each location.
Landplane has restored several worn driveways to looking like they were freshly rocked. Amazing tool. With only moving a couple inches of material on top. Without using scarifiers. Builds and maintains a solid durable driveway.
Scarifiers don’t work in most of my driveway. Have never needed them to work the driveway. Have used them to help smooth rough sections of pasture and lawn.
Like to thank everyone for the input. Sounds like I better plan on just moving gravel from places cars don't go to where they do.
   / Bringing old gravel to the surface #8
Scarifiers only loosen up the material. They do not move it to the top.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A55973)
2007 Sterling...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Hose Reel (A55758)
Hose Reel (A55758)
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
