bringing barn floor up to grade
   / bringing barn floor up to grade #1
gunyo
i just put up a 40x70x14 pole barn and my problem is across the width of the barn the the ground drops off about 15 inches so the bottom of the barn siding is 3 inches above the ground on one side and 15 inches on the other side can i just backfill with sand inside to get up to grade and then top it with gravel the skirt boards are to the ground all the way around the perimeter so i think that will contain the sand
   / bringing barn floor up to grade #2
Welcome Gunyo.If your skirtboards are framed all the way up to the siding go for it.There's really no other way to do it.Mine was a foot out side to side as well, worked fine for me.;)
PS.Fill out your profile it comes in handy when answering questions.:D
   / bringing barn floor up to grade #3
I had same problem one corner was nearly 30" of fill required for my 50x50
so Used a compactable fill material sand gravel clay mix. make sure to compact the LIFTs no more than 6" of fill b4 compacting. water down & re-compact & add more fill after a setteling time is best but if using vib compactor then you can add lifts right on top but setting time is best if crete is going to be used...
mark M
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
6 Pallets of miscellaneous PPE (A53117)
6 Pallets of...
2012 FORD F-450 XL SUPER DUTY BUCKET TRUCK (A51406)
2012 FORD F-450 XL...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
