Bring on the weeds "Homemade Sprayer"
   / Bring on the weeds "Homemade Sprayer" #11
Re: Bring on the weeds \"Homemade Sprayer\"
SHOULD you or COULD you?
You probably could, but I have no idea if you should.
You need to think through your plumbing and pressure. If you are going to leave the PTO pump running then you have to make sure you don't overpressurize the tank or will you use the PTO pump to draw fluid out of an unpressurized tank and simply spray with pump pressure? If so then will you add a tank agitator to keep your chemicals mixes or allow them to settle and manually mix them periodically?
The same questions need to be asked no matter what type of pump you use, but I think a PTO pump may be a bit more problematical in some respects, especially with a small system.
So here is my question, why not just buy a 3pt spray rig that is already built? I know they have 3pt rigs of that size available.
In my case I don't have the need of a rig of that size, and I want DUAL tanks, so I can have an "organic only" tank for the veggies and I can have a "chemical" tank for spraying the ditch line, etc. I ended up buying 2 ATV tree sprayer rigs, and I will be making a custom 3pt carry mount so both rigs will be carried on the hitch. The more I looked into the plumbing & pressure issues the more I realized I did NOT know about how to properly design a system, so I simply bought the components and will modify them to suit my needs. My pumps are a little higher capacity, but still basically standard pumps, the sprayers are spray guns that are supposed to, when used with the pumps I got, spray up to 35', and are not the typical "wand type" sprayers that are often seen (nothing wrong with a wand sprayer, it is just not what I wanted -- we each have different needs).
I am hoping to have my rig done by late April (won't get started on it until after Easter because of work schedule & a week vacation).
   / Bring on the weeds "Homemade Sprayer" #12
the size of the tank has nothing to do with pump size. pump size is based on flow rate. if you have a handheld wand you don't have a very high flow rate so you can easily get by with these pumps. if you put a multiple nozzle boom on the back with large orifices in the nozzles you would need a high flow pump like the pto pump.don't forget about keeping the solution mixed. you cannot rely on the sloshing in the tank because it may not be sloshing when you need it to. tank size is based on how many acres or sq.ft you want to do at a go. I have seen sprayers in the old days that had a small propellor built into the tank, seals leaked terribly. the usual way is to have a large enough pump coupled to a release valve that adjusts and holds the pressure at a constant and the rest jets back into the tank to keep mixing.I hope I helped it's been 20 years since I was in the business.
   / Bring on the weeds "Homemade Sprayer" #13
I didn't mean to say that you need a PTO pump for a large tank and not for a small one, I was trying to explain that based on the cost of the PTO pump, it didn't make sense to pay for a PTO pump with a smaller tank under most circumstances. Sorry if I was not clear.
   / Bring on the weeds "Homemade Sprayer" #14
I agree with you, I always hope that I'am not misunderstood because sometimes what's inside the head that seems clear doesn't always make it out the ends of the fingers.lol
   / Bring on the weeds "Homemade Sprayer" #15
I've never thought about this.. pressure issue turning off the pump. I have three units right now 2- 15 gallon tanks and a 25 gallon tank. I am looking at moving up to a 60 gallon tank that runs off of a PTO pump. So what exactly happens when the pto pump is running and you don't squees the sprayer wand? What happens to the pressure. Does it just recycle through the tank?
   / Bring on the weeds "Homemade Sprayer" #16
That totally depends on the design of your system.
Chucko, Bob hit the reason on the head! A 12 volt pump for $10.00 plus I can use it on other equipment if needed,4 wheeler,golf cart, small mower etc. I will only use about 15 gals of roundup all year so I don't need a big pump for spot spraying. So for me this worked, a good sprayer setup and I have under $50.00 in the whole thing.
Chucko; 50 gal of water,tank,pump.hose,brackets!! Watch your weight on a BX 1800
   / Bring on the weeds "Homemade Sprayer" #19
Chucko. . . conservatively figured a 50 gallon spray rig will weigh 425 pounds for the liquid, another 100 pounds for the frame, pump, etc. for a conservative 525# and 550# or more would not be a surprise. I'd bet that you lift the front end of your tractor off the ground if you have a BX.
   / Bring on the weeds "Homemade Sprayer" #20
</font><font color="blue" class="small">( once your tank is pressurized you want the pump to shut down)</font>
This is a different scheme than I have seen before. From the way I have my pump (Harbor freight 15 gal with wand), the tank is not pressurized. The hose between the pump and the wand is pressurized. I would think it would be this way in an RV as well...you would want your pipe pressurized and not the tank.
So, the way my pump works, it shuts off when there's enough pressure in the hose. When I release the pressure by openning the valve on the wand, it begins pumping. This works great for me.
The other reason I can think of for not pressurizing the tank is that the tank then needs to be airtight. Mine is ventilated to allow fumes/pressure to release in the heat...and to prevent a vacuum from building.
Sam
2015 GMC Yukon XL SUV (A56859)
2015 GMC Yukon XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2017 Kubota M5660SU (A57148)
2017 Kubota...
2011 DOOSAN G25KW GENERATOR (A58216)
2011 DOOSAN G25KW...
