Briggs Vanguard HELP!
/ Briggs Vanguard HELP! #1
subergoo
I have a 16 horse power Briggs Vanguard V twin over head valve #303447. This engine has about 3000 hours on it and has run great for the past 2999 and has been very well maintained all its life. Recently it lost power and started blowing blue/black smoke out the exhaust. This condition has gotten MUCH worse, its smoking so much now that it fills a three car garage in under a minute. It now only runs under full choke and has little to no power.
I then replaced the carb with a new one, new plugs sparking fine, oil changed, two new head gaskets, fully inspected heads and valves, compression checked out to about 110 psi on each cylinder cold, air filter good and clean, new intake manifold gaskets, new fuel pump.
After doing all this the engine STILL does the exact same thing. Only starts up and runs with full choke at 50% throttle or more, smokes like crazy, and still has no power.
HELP ME PLEASE.
/ Briggs Vanguard HELP! #2
How about your PVC system ? Could be building pressure in the crankcase.
Ingersoll Rand DD-24 Tandem Smooth Drum Vibratory Roller (A64553)
Ingersoll Rand...
2022 EZ-GO ELITE...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
Connect CH65 Hydraulic Breaker Excavator Attachment (A64194)
Connect CH65...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2022 EZ-GO ELITE...
