Your filter being loose, then tightened again- did it change anything?
These engines definitely had their share of coil problems for a hot stall. Sometimes the CD would be wiggy and begin to throw the spark at the wrong time. The thing to know before you replace a coil is that these machines are old, harnesses brittle and you should confirm that there is never any power getting to the coil. Crank, run, stop. wiggle this an that. The OEM replacement coils are really sensitive when it comes to stray power hitting them. AN aftermarket coil could be better.
