Briggs and Stratton 190432 - Threw a rod
   / Briggs and Stratton 190432 - Threw a rod #1
SmellsLikeaGoat
Wayne, Oh
Ford 2000
There is a 1/2" x 1" hole in the side of the engine (blown out from the inside) and I can look through ans see that there is nothing connected to the crankshaft.
Is my engine toast?
   / Briggs and Stratton 190432 - Threw a rod #2
In a short answer, yes. Most likely lack of lubrication failure which resulting in the rod seizing to the crankshaft which in turn broke, and went through the side of the block.
I figured. There was enough oil. I've checked that regularly ever since I let it run dry and it seized up two years ago. I pounded down the piston with a big hammer and a chunk of 2x4 and got two more years but it was living on borrowed time.
   / Briggs and Stratton 190432 - Threw a rod #4
You did well to get two years after the damage from two years before.
2016 KENWORTH T270 SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
TEST BID LOT (A50775)
2019 FORD F-550 SERVICE TRUCK (A53843)
2019 FORD F-550...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A52705)
2021 HAMM HD+9I VO...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
