forgeblast
Elite Member
To figure out your % of alcohol you need to take a reading before you add your yeast, this is your original gravity, then you take a reading before you bottle (final gravity) and subtract the two. This lets you know your % of alcohol.
Can be done on a couple of different scales and you can use a couple of different tools.
most use a hydrometer which has the scales on it. You must, if measure at a higer temp adujust for temp.
Using you hydrometer will also let you know if your yeast are done or got stuck, this is important in high alcohol content beers, where you want to pitch more yeast then normal.
