Breaking up WAS hard to do - rototiller breaks up ice
   / Breaking up WAS hard to do - rototiller breaks up ice #1
tractorgp
Platinum Member
Newfoundland
Kubota BX25
Here you go
   / Breaking up WAS hard to do - rototiller breaks up ice #2
Well, O.K. then.
   / Breaking up WAS hard to do - rototiller breaks up ice #3
Does seem to work.
Kinda wondering what the sidewalk is going to look like though ??? :eek:
   / Breaking up WAS hard to do - rototiller breaks up ice #4
wow, that is one way to do it....
   / Breaking up WAS hard to do - rototiller breaks up ice #5
I can see myself trying that!!!! :)
   / Breaking up WAS hard to do - rototiller breaks up ice #6
Then swap the string trimmer head onto it...great for removing wallpaper.
Like the fellow across the road growing up, he would go through his salad patch with a push mower/grass catcher on it. Throw that into a big cauldron with a fresh road kill deer he cut up with a band saw.
Yum-yum!
   / Breaking up WAS hard to do - rototiller breaks up ice #7
Does seem to work.
I was thinking the same.......probably worth using a tiger torch instead.
Even if the torch was a bit slower, I'd be using that myself..... between the tines and that engine, that's pretty much the most annoying mechanical noise I've heard in quite a while.....:cool:
Rgds, D.
   / Breaking up WAS hard to do - rototiller breaks up ice #8
Kind of reminds me, of when I tried to blast out bedrock with a .308!
Does seem to work.
Asphalt not fazed by it. Pickaxe or ice chipper probably harder on the driveway.
Cat TH407C Telehandler (A52748)
Cat TH407C...
P.T 8' Offset Disc Harrow (A50120)
P.T 8' Offset Disc...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
2000 Ditch Witch 3700DD Ride-On Trencher (A50322)
2000 Ditch Witch...
2018 JCB 507-42 7,000LB Telehandler (A50322)
2018 JCB 507-42...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
