Breaking new ground. What a PITA.
   / Breaking new ground. What a PITA. #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
I recently set about preparing new ground that I know hadn't been worked for better than a century. 47HP 4wd tractor with a 14" two-bottom dearborn plow. The roots and rocks and muck defeated me. There were ancient Grape roots (those things are tough), hundred year old maple roots, Siberian Elm, and walnut.
So I took a ripper to it and that made a complete mess of things. I then used a grapple to get the roots out. That made a bigger mess. Some roots were 6" in diameter. Now I got holes hills and it's a mess. I'll take my Howard rotovator to it and see if I can use that to bring it back to more or less level.
No box blade, no rear blade, no land plane.
   / Breaking new ground. What a PITA. #2
When you finish ... I've got a 20 acre section you can work on.
   / Breaking new ground. What a PITA. #3
1. We are just days before winter begins. Why oh why are you ripping ground now ?
2. Double ganged notched disc harrow. Likewise, my ground out here had not been touched in 70 years. This tool ripped and shredded everything under the surface. Just a few passes and it began to look like great soil again.
Sub-soil 8-inches depth.
TADA, no more wild grape roots !
Roots. I'm ripping the roots so that I can work the soil. Plus I have a water issue and I'm breaking the hardpan hoping it'll perk down.
Never done this before.
I have a pile of mushroom compost I want to work in before the snows.
   / Breaking new ground. What a PITA. #6
This is just like remodeling a house. Make a mess then make it pretty. Use your ripper and make a N-S then a E-W grid to bring up everything that you can. Use your grapple to remove every thing you can. It will be a chore. Find an old railroad tie or piece of an I-beam to make a drag and smooth it back out. Then try to plow it again. I would not use the rotovator until every thing was picked out.
   / Breaking new ground. What a PITA. #9
Did something very similar this past summer with my 39 hp kubota. Started with a two gang notched disc. Very little impact.
Sprayed with roundup and mowed as low as possible. Once that was done my disc started to cut. Grabbed a two bottom plow and turned all of it over east to west. Disc once same direction and then 90 degrees opposite. That second time was horrible bouncing across the field. I finally gave in and bought a pto tiller. That was my best bet. I was wasting time prior to using the tiller.
I was lucky that i wasn't fighting any vines and only had to find a few rocks. I plan on doing more this summer with these steps.
Cut low
Spray and let die off
Tiller a few times in low gear
Wide drag for leveling
   / Breaking new ground. What a PITA. #10
One of the stories I grew up with is of my great grand-father watching my grand-father break a new ground in the 1920's. Every time the mule pulled the turn plow under a root Granddad had to pull it back and lift it over. My great grand-father turned my great grandma and said he'd never heard a family member curse so much.
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
