Break in period, Suggestions Kohler 23 V-Twin
   / Break in period, Suggestions Kohler 23 V-Twin #1
Corvus
Hi Folks,
Just wondering what type of break in routine I need to use for my new Z-Force 50. I understand I need to change the oil and filter after 5 hours of use . . . anything else . . .
Should I avoid long periods of full throttle, should I vary throttle speeds?
Anything to avoid durning the first hours of use?
thanks
Corvus the Crow
Oh and . . . there was an old school of thought that suggested you use an rag covered in WD40 to wipe down the frame and deck of you mower . . . instead of waxing it or anything . . . what do folks recommend to prevent rust and paint deterioration ?
thanks
/forums/images/graemlins/confused.gif
   / Break in period, Suggestions Kohler 23 V-Twin #3
Just run it normally & change the engine oil & filter after 5-10hrs. There is no real way to vary the throttle while under use as you need full throttle for the mowing deck and hydro /forums/images/graemlins/confused.gif. WD40 is one heck of a cleaning agent, fairly good water repellant, not much of a lubricant. It works great to get adhesives, tar, & sticky gooey stuff off! It wont hurt your paint/finish at all.
G/luck
Joel
   / Break in period, Suggestions Kohler 23 V-Twin #4
Check in the Owner's Manual. With the tractors (mine at least) there was a break in schedule for both the engine and the PTO clutch.
I would suspect the RZT would have the same ... but maybe not.
Ed
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
