Break in period, Suggestions Kohler 23 V-Twin
   / Break in period, Suggestions Kohler 23 V-Twin #1
Corvus
Hi Folks,
Just wondering what type of break in routine I need to use for my new Z-Force 50. I understand I need to change the oil and filter after 5 hours of use . . . anything else . . .
Should I avoid long periods of full throttle, should I vary throttle speeds?
Anything to avoid durning the first hours of use?
thanks
Corvus the Crow
Oh and . . . there was an old school of thought that suggested you use an rag covered in WD40 to wipe down the frame and deck of you mower . . . instead of waxing it or anything . . . what do folks recommend to prevent rust and paint deterioration ?
thanks
/forums/images/graemlins/confused.gif
   / Break in period, Suggestions Kohler 23 V-Twin #3
Just run it normally & change the engine oil & filter after 5-10hrs. There is no real way to vary the throttle while under use as you need full throttle for the mowing deck and hydro /forums/images/graemlins/confused.gif. WD40 is one heck of a cleaning agent, fairly good water repellant, not much of a lubricant. It works great to get adhesives, tar, & sticky gooey stuff off! It wont hurt your paint/finish at all.
G/luck
Joel
   / Break in period, Suggestions Kohler 23 V-Twin #4
Check in the Owner's Manual. With the tractors (mine at least) there was a break in schedule for both the engine and the PTO clutch.
I would suspect the RZT would have the same ... but maybe not.
Ed
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
Year: 2002 Make: Western Star Trucks Model: 4900 SA Vehicle Type: Truck Mileage: Plate: Body Type: (A51692)
Year: 2002 Make...
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
Chevy 2500 Pickup (RUNS) (TITLE) (A50774)
Chevy 2500 Pickup...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
