break caliper bolt - how to secure it
   / break caliper bolt - how to secure it #1
RancherSam
Hays County, TX
Case IH JX95 4x4
Hello everyone,
I recently changed the ball joints on my srw 2004 f350 diesel. Recently I found out that the rather sizable bolt that holds the brake unit in place came out ( this is the 2in by 1/2in bolt ). We had torqued it to 150 ft lbs but apparently that wasn't enough ( btw this is not the bolt that holds the brake pads - that one was fine ). I don't think I will be undoing this again anytime soon so I need it to stay! What do you all recommend I do in addition to torquing it again to 150.
   / break caliper bolt - how to secure it #2
loctite 262
you'll have to heat it to get it loose next time around
   / break caliper bolt - how to secure it #3
Ditto on the Locktite. Good stuff. :D
   / break caliper bolt - how to secure it #4
Loctite is what is used in that application due to the vibrations.
   / break caliper bolt - how to secure it #5
Hello everyone,
With all due respect , a 2X1/2" bolt tightened to 150* will take a bit to undo again . Are you certain it was not overlooked on assembly ?
   / break caliper bolt - how to secure it #6
Loctite. Mine '99 had factory Loctite on those bolts.
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2007 INTERNATIONAL PAYSTAR 5600I (A52472)
2007 INTERNATIONAL...
