brazing a hydraulic line
   / brazing a hydraulic line #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
I have a small leak in the metal pressure hydraulic line right at the fitting. It leaks a couple of drops per minute. I was thinking maybe I could braze it shut. I cannot even see where it's leaking. At home depot they have 3 or 4 kinds of braze - bronze, nickel-silver, and a couple of others (aluminum maybe). A replacement part is $250.
   / brazing a hydraulic line #2
Silver solder should do the trick. Brass would probably be fine too.
Just regular old silver solder? the stuff used for copper pipes?
Just heat the joint up.. and apply the solder?
I suppose it best to sand off as much paint/corrosion as I can..
   / brazing a hydraulic line #4
I'm pretty sure Redrocker meant real silver solder. Typically you need less heat than brass which is nice for small/thin stuff. A welding supply should have it. If not a place that sells jewelry making supplies. It comes in several melting point temps. And it uses it's own kind of flux.
   / brazing a hydraulic line #5
I agree with RedRocker, silver solder will work just fine.
Be sure to prepare the area by removing as much paint and crud as you can around the area. Then apply the flux neatly and evenly. The flux application is key to a good job because it controls the flow of the solder. I use Harris "stay-silv" silver solder flux.
   / brazing a hydraulic line #6
If you can't see where it is leaking, how are you going to solder it? Are you going to solder the nut/connector to the steel line? Maybe it is leaking at the seat, or o-ring if it has one, and removing the connection might reveal the source of the leak.
   / brazing a hydraulic line #7
"Just regular old silver solder? the stuff used for copper pipes?"
That's not silver solder...that's a lead/tin alloy used to sweat copper joints.
Real silver solder will require more heat...probably MAPP gas (at least).
You can give it a try, but I'm not sure any solder will work on a hydraulic system that pushes >2000 PSI. Of course, some aerospace hydraulic fitting are silver soldered...I know...I did some whilst in the Navy. But these joints were not pinhold leaks.
Can't hurt to give a try though!
   / brazing a hydraulic line #8
I agree - that is a lot of pressure for a soldered connection.
   / brazing a hydraulic line #9
I don't know what you have in your area, but you could take the old line to a hydraulic shop. We have one in the area that makes up metal lines as well as hoses. It would be a LOT less expensive than the dealer.
   / brazing a hydraulic line #10
You might want to read up on silver soldering, aka silver brazing ... it's pretty strong ... nothing like soft-solder. Also, around these parts, lead in solder, for potable water, has been outlawed for a long time ... kindof a safety issue. One compound for potable water pipe soldering uses tin, copper and selenium.
Cheers!
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
