Brass Radiaor. How do you descale?
   / Brass Radiaor. How do you descale?
I have a bunch of 20 degree Muriatic acid, not that the designation means much to me. Should I use that? Dilluted?
Thanks for the expertise.
   / Brass Radiaor. How do you descale? #12
I would try the vinegar first. Safest to use. If you need stronger after several soakings then just go to a larger restaurant and ask them if they will hook you up with a gallon of Lime-a-way. Not knowing the concentration of the acid you have I would not be comfortable recommending a dilution ratio. Remember to rinse very well after each soaking.
It does make me wonder now, if it's truly lime I am tying to get rid of.
   / Brass Radiaor. How do you descale? #14
Wouldn't surprise me at all that it is lime scale. I don't know what water hardness is in your area or the area where the radiator was before you. But it can change in a short distance.
Here it is around 2 grains which is not horrible. The DFW area has around 6-15 grains depending on where you are. I have tested 36 grains in Big Spring TX. I don't know how they live out there.
Then some location have high iron or manganese. Acids help with these as well. Chlorine and high temperature will make these conditions worse. That is why using distilled water is important.
Edit: Sorry, probably more info than you are looking for. Lol
I looked over my records and found where I installed a block heater and changed the STAT but it doesn't say if I changed the coolant.
Should I rig up something that circulates the Vinegar within the rad? That might actually be a fun project. Maybe even an inline heater? I get a kick out of using all my junk and Magivoring things.
   / Brass Radiaor. How do you descale? #16
That certainly could help! :thumbsup:
   / Brass Radiaor. How do you descale? #17
I assume you have exhausted options within the automotive industry. A brass radiator would be an anomaly these days as smaller radiators are now throw-aways being aluminum and plastic. There went the old radiator shops and their hot acid baths.
Muriatic is an industrial grade Hydrochloric acid. Same stuff, Muriatic is normally limited to 20% strength. Reminds me of my industrial refrigeration days with shell and tube and shell and coil condensers and evaporative types of cooling media equipment. What ever acid you use it needs to have a copper/brass inhibitor to keep the acid from eating those metals. You did not really indicate the thickness of the deposits. The heavier the longer it takes. You will also need litmus paper to determine when the acid is neutralized by the alkaline deposits. PPE is a must, rubber gauntlet gloves and apron and face mask. Get the safety data sheet with it and follow to the tee. You add acid to the water not the other way around.
Circulation or immersion bath will be necessary to reduce acid loss and it may not be cheap if deposits are heavy. Circulation will be the fastest and easiest and use the least acid per batch. Any good industrial supply house should be able to get the acid with proper inhibitors or know where to get it.
Another milder but effective product around metals is Sulfamic Acid which is the base chemical for use in refrigeration industry cooling towers and such, less agressive that Hydrochloric. It is safer to use also. We used it when equipment could not be shut down. Dump in the sump and let it circulate with the process. Again you have to keep tabs on the PH to maintain strength.
Worst one I encountered was an evaporative condenser (lots of small copper tube bundles in and air/water shower system. It was a supermarket application for all their many compressors. It was in an area that had a huge cement manufacturing plant, there was cement dust in the air constant. Shut down for initial cleaning with acid and scrapers till the systems could gain operation. That was two days 24hr ops. We used Hydrochloric as the Sulfamic did not phase it. We then left it circulating (the unit has a large sump) during operation checking strength every 4 hours and cleaning out the sludge. That went on for 2 weeks and it got fairly clean. Our engineer designed a air-cooled condenser system which we installed the next year.
Hoe this helps and lots of luck. Above all BE SAFE acids can be very disfiguring. Any thing can be done if you throw enough time and dollars at it.
Ron
   / Brass Radiaor. How do you descale? #18
For what it's worth (?); I remember my dad using boric acid to flush the radiator in his '36 Pontiac and later vehicles. Did it work (?), I don't know, but my father did not waste time on things that didn't
UNUSED FUTURE SE61 - 61" HYD BROOM (A54757)
UNUSED FUTURE SE61...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A55788)
2017 Ford F-350...
2017 Rockwood Esp Pop Up Camper (A51694)
2017 Rockwood Esp...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
