Branson serial #'s
/ Branson serial #'s #1
brianb88
Iuka, MS
Branson 5220R/FEL
Does anyone know where to find the year of a Branson tractor by it's serial #? I have the 5220R and I think it is 2013 but I cant find any info anywhere. Serial # is CELD00011.
Thanks in advance!
/ Branson serial #'s #2
Does the engine have a decal stating meets EPA regs for a given year? I use this as an estimate of the age of the vehicle. Not sure on the serial number identification
No it doesn't, but thank you. I'm pretty sure that the Tier 4 regs started in '14 and mine doesn't have any epa sticker that I could find. I bought this new first of '15 and I'm thinking I got the last '13 model on the lot. I was just hoping that I could identify the year by serial # but as far as I can tell that isn't possible.
/ Branson serial #'s #4
Thanks in advance!
Do you have a dpf filter?
/ Branson serial #'s #6
Your tractor is a 2014.
/ Branson serial #'s #7
02/06/15 is the date the original warranty for your tractor was registered, so i'm gonna say your was a 2014 year end production. if your doesn't have the DPF then count yourself lucky you got one of the last of the production run that don't require the emissions system.
/ Branson serial #'s #8
As in my lineup, I have a 2016 2400 with the A1100 engine, tier 4 and all it has is a PCV hose. Tractors under 25-26 hp don't have the heavy emission controls like larger tractors. (reference: my memory)
/ Branson serial #'s #9
I have 4720H serial #CLKE00011. was wondering what year it is. Bought April 2015. Weird coincidence that original poster, brianb88, and I have very similar serial number. His is CELD00011. Appreciate any help.
/ Branson serial #'s #10
According to branson your tractor's date of purchase is 04/13/2015,
/ Branson serial #'s #11
don’t know how you come up with that info but really cool that you did. thanks.
/ Branson serial #'s #14
i have a program i can look up Branson Serial Numbers, most dealers will have this if they preform warranty work on Branson's.
/ Branson serial #'s #15
my Branson 2400h serial number is CV8V00042 what year is that?
/ Branson serial #'s #16
that number doesn't pull up in the system, can you double check the number for me, you should find it at the front left hand side of the tractor where the hood meets the frame there will be a metal placard with the serial number engraved on it
/ Branson serial #'s #17
/ Branson serial #'s #19
Thank you, Branson seems to hold a lot of information close to their chest. I was looking for a oil seal for front axle and the only way I could find it was going through the dealer.
thanks again
/ Branson serial #'s #20
Most oil seals are generic and measurable to source them.
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
PALLET OF GANDY APPLICATORS (A64278)
PALLET OF GANDY...
