Branson F47Chn ballast
/ Branson F47Chn ballast #1
Branson 47F series cab
I have a Branson F47Chn with a 4 in 1 front loader which is pretty heavy, can anyone give me an idea of what weight of ballast block should I put on my 3 point arms to counter my front loader please?
michael
/ Branson F47Chn ballast #2
Many variables to that question. Are your rear tires filled with ballast? Are you going to run a grapple, or other heavy attachment on your FEL? Are you digging into hard dirt with the bucket, or just hauling loose gravel and sand?
I would run around half of your 3 point hitch lift rating in ballast on the rear, if it was me. If your rear tires are filled, then you could back that off and run a bit less weight. My thought is that within reason, you really can't have too much rear ballast when using the FEL.
/ Branson F47Chn ballast #3
Depends too on what you have for front tires.
Rear ballast (to some extent) unloads the front tires.
I prefer to have a useful implement on the back, rather than mere weight.
213324 (A64279)
213324 (A64279)
2014 Jeep Patriot SUV (A64557)
2014 Jeep Patriot...
2022 EZ-GO ELITE...
2020 KUBOTA RTV-X1140 UTV (A63276)
2020 KUBOTA...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2014 Ford F-150...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
