BRANSON F4350 FARM TRACTOR POWER PROBLEM
   / BRANSON F4350 FARM TRACTOR POWER PROBLEM #1
PEM
Corrales, NM
Branson F4350
If someone can, please help:
my Branson F4350 all of a sudden has no power to the On/Off key SWITCH/STARTER; thought it was the Battery, so I purchased a new one today-STILL NO POWER. Does anyone have any suggestions where/what the problem may be, and how I can attempt to fix.
I would appreciate all the help.
Thanks, Phil
   / BRANSON F4350 FARM TRACTOR POWER PROBLEM #2
Check your safety switches, clutch, pto, seat etc.
   / BRANSON F4350 FARM TRACTOR POWER PROBLEM #3
See if you can find a master fuse, like 30 t0 40 amps. Most of the ones I have seen are in the wire hooked at the starter along with the battery + cable. It well be the main feed for the dash and switch.
   / BRANSON F4350 FARM TRACTOR POWER PROBLEM #4
It may also be a fuseable link, which is actually part of a wire that can melt, acting as a fuse.
It looks like a bump in the wire.
If so, replace it, don't jumper it.
Napa has them.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
JOHN DEERE 9520 LOT IDENTIFIER 257 (A53084)
JOHN DEERE 9520...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
