Branson 4720H Whine
   / Branson 4720H Whine #12
I look for 2 specs for my tractors, not because I have a JD (which I had several and currently don't) but because if any spec is posted, J 20C shows up for the premium fluid required in today's tractors, and JD 303 shows up for the yesteryear tractors like my Fords.
The whine in hydraulics usually is little bubbles in the fluid cause by a compression of some sort in the line changing the flow from "laminar" to restricted/released, causing "turbulent" flow where the release is essentially a vacuum "pulling the oil apart" sorta thing.
The hotter the fluid the more volatile and the easier it is to "pull it apart". The hydraulic circuit is a closed loop and the pump is pumping on the one hand and sucking on the other....source of the vacuum. It's kind of like boiling water. At one atmosphere it boils at 212F but if you pull a vacuum on the container you can get it to boil at a much lower temperature. Not a hydraulics expert but that's how I see it.
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2019 FREIGHTLINER CASCADIA T/A DAYCAB ROAD TRACTOR (A51243)
2019 FREIGHTLINER...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
