Branson 4720H PTO problem
   / Branson 4720H PTO problem
thanks I will check the wires
   / Branson 4720H PTO problem #12
My 3725 has three positions on the PTO switch-off, link and on. The link position is linked to a position sensor on the 3pt. When in that position the PTO comes on when the 3pt is lowered and shuts off when it's raised. If yours has that and that's the position you are using, check the position sensor and it's wiring. The sensor on mine is on the left side 3pt raising arm where it comes out of the transmission housing.
   / Branson 4720H PTO problem #13
Just to add a bit more on what ericm979 said, when the switch is on Linked position, it will also stop the PTO when pressing the clutch on Shuttle shift tractors. Yours is hydro so it doesn't really matter for you.
(2) 2" X 6" UP TO 40' TUBING (A57192)
(2) 2" X 6" UP TO...
YANMAR RS1300 54" ROTARY TILLER (A57192)
YANMAR RS1300 54"...
1997 Caterpillar D3C Series III LGP Crawler Tractor Dozer (A55851)
1997 Caterpillar...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2009 KENWORTH T800 DAY CAB FLAT TOP ROAD TRACTOR (A57192)
2009 KENWORTH T800...
2017 Nissan Frontier Ext. Cab Pickup Truck (A55852)
2017 Nissan...
