Branson 4720
/ Branson 4720 #1
ucfd070
Ga
none
I have a 2005 Branson 4720 with the Ag tires. I have found a set of Kubota 6060 turf tires and wheels.
size These are new take offs from a Kubota 6060. Front size is LSW 305 R 343 and the rear size is 610 R 470.
My question is will the wheels fit my tractor? are the bolt patterns the same? 8 lug. or are these too wide?
I'm tired of tearing up my pastures.
/ Branson 4720 #2
First off you need to measure the circumference of you rear tires and of your front tires. Determine the ratio between the two and see if the ratio is the same for the Kubota tires. Then you will need to measure the bolt circles from each to see if they match.
JOHN DEERE 2950 TRACTOR (A62130)
JOHN DEERE 2950...
2001 Eager Beaver 50 Ton Hydraulic Detach Lowboy Trailer (A64047)
2001 Eager Beaver...
43023 (A59228)
43023 (A59228)
2022 BIG TEX 22GN-35BK+5MR T/A 48FT GOOSENECK TRAILER (A59909)
2022 BIG TEX...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
