Branson 3820i
   / Branson 3820i #1
kedwards
Branson 3820
Okay, question........My dumbass put too much oil in my tractor, it's a Branson 3820i. It now has some oil in #2 cylinder. I pulled out the glow plugs to see this. Question is can I turn over the engine safely with out the glow plugs out? Or what is a better way to get the oil out?
Thanks,
Kenny
   / Branson 3820i #2
Thanks,
Kenny
Yes, just make sure all are out (no compression, so it can't start). Best if you can cut off the fuel supply somehow.
Also, since the glow plugs are out and no compression, it would be better if you can rotate the crankshaft manually (should turn easily if you can find a place to put a wrench) and put a towel over top the engine.
   / Branson 3820i #3
Maybe try engaging and turning the pto drive with the tranny in nuetral, it will be slow but will keep you from jamming anything as the oil oozes out:thumbsup:
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A48081)
2022 Ford F-150...
2004 Freightliner M2 106 Ambulance (A48081)
2004 Freightliner...
Platform/Catwalk (A50860)
Platform/Catwalk...
Excavator Bucket (A50860)
Excavator Bucket...
2015 Dodge Durango SXT SUV (A50860)
2015 Dodge Durango...
