Branson 3510 two oil filler caps on engine?
   / Branson 3510 two oil filler caps on engine? #1
Phil1959
Maine
Branson 3510
This might be a stupid question. Why is there two oil filler caps on the engine? One is in the normal location top of engine the other is on a seperate assembly on the right side of the engine. Both are orange caps labled oil.
Suprised at the lack of respones on this forum.
   / Branson 3510 two oil filler caps on engine? #3
I find this alot on tractors. The side one is just an easier service port. They both fill the same case but sometimes the top one is hard to get to on some tractors.
   / Branson 3510 two oil filler caps on engine? #4
The reason why is because, whether its a Kukje or Cummins A-Series, the engines that are used are also manufactured and sold for use in smaller, industrial equipment. They put two on there just in case if say the top or side of the engine was blocked by bodywork you would still be able to fill it up with oil.
   / Branson 3510 two oil filler caps on engine? #5
It's a universal thing. As stated allows the engine to fit other applications.
I have a Kohler Marine Generator with a 4 cylinder Kohler engine. I has a fill point on both sides and a dipstick on both sides also. This allows the Gen to be installed right,left,front or rear.
   / Branson 3510 two oil filler caps on engine? #6
Thanks for this post. I just bought a Century 3035 (same as a Branson 3510) and I had the same question. Answer not found in the manual.
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
Landoll Lowboy Trailer (A55218)
Landoll Lowboy...
