Branson 2910i Tym eqivilent
/ Branson 2910i Tym eqivilent #1
sullyco
none
Does anyone know if their is a sister brand the same as the Branson 2910i
/ Branson 2910i Tym eqivilent #2
The 2910i is an older Branson model that has not been made since about 2009. TYM did not buy into Branson until 2016 so they dont really have the same unit.
NOW if you are just looking for a TYM Tractor that is similar in size and performance then that would be the TYM 3515, (R model is shuttle shift, H model is hydrostat)
35hp at the engine (Kukje A1700 engine) super simple mechanical diesel, same platform as the 2910i has.
The loader has a lift capacity of 2,200 lbs.
/ Branson 2910i Tym eqivilent #3
Technically, the 3015R would be the closest equivalent. It is exactly the same as what was described above, but with the engine rated to match the 2910i.
You could argue the 3520R is closer. The weight of the 20 series is only about 100 lbs more than the 2910i. The 15 series is about 500-600 lbs lighter.
