Branson 2400h parking brake sticking
   / Branson 2400h parking brake sticking #1
Ductking1
Branson 2400h
Hi to all, I have a 2019 Branson 2400h and when I use the parking brake, not very often, but when I release it the handle seems to work fine but the brake doesn't release or not completely I have to run the tractor back and forth until they loosen up, any help would be greatly appreciated, thanks.
   / Branson 2400h parking brake sticking #2
On my 2400H the handle must be all the way down to the floor or the brakes drag a little. I use the brake so infrequently it never bothered me enough to look at the adjustment.
I'm pretty sure the handle is going all the way down going to look it over some this week to make sure nothing is binding and if there is a mechanical adjustment I don't know much about a wet brake system but I'm hoping it's something external.
   / Branson 2400h parking brake sticking #4
I would start by crawling underneath and spray some penetrating fluid on the shafts that enter the transmission housing along with the rest of the linkage and work those brake pedals. Usually those have an easy way to lube and eventually start seizing over time.
Also check the pivot shaft for the brake pedals, those do typically have grease fittings.
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
