Branson 2400 transmission help
   / Branson 2400 transmission help #1
JWitte
Branson 2400
I have a 2015 "00" series bought used. While working one day I heard a pop and the shifting lever started moving freely while in reverse. I shut it off and now it will not start. After much research, I found that the main shift arm is broken. I got the new part in and back in place but the shifter still moves freely and will not shift into any other gear. I have drained the fluid and inspected the gears, all look good with very little to no wear marks. I am at a loss and hope someone here can help me out.
Thanks, John
   / Branson 2400 transmission help #2
I am not sure if you've gotten this resolved or not by now, and I'm not familiar with that model, but some of the transmissions have a shift fork inside the transmission where one side can brake off and not slide the gears, sometimes the roll pin itself can shear and cause it not to move the shifting fork as well. When this happened on one of my other brand tractors, it required me to split the tractor at the rear transmission.
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
2015 BOBCAT E35 EXCAVATOR (A51242)
2015 BOBCAT E35...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
Wolverine Quick Attach Stump Grinder (A50514)
Wolverine Quick...
