jpilk99
- Joined
- Feb 19, 2011
- Messages
- 375
- Location
- Bolton, MA
- Tractor
- 1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Hi all.
I have a Husqvarna LGT24K54 and love it. I've had it since brand new and it's 8 years old. Getting ready for this season's mowing/etc., I changed the oil/filter/plugs and decided new belts would be a fine thing to do. The mower Drive belt was working ...okay, but, only for about 10-15 minutes. Once warmed up, I had a hard time getting up hills. So, while under the machine installing the new drive belt, I had the deck out and replaced the Deck belt too. It was working well, but, it looked worn.
Now, when I'm all excited to start cutting the grass, within a second or two of engaging the mower deck, the belt jumps off. I thought it was a freak occurrence the first time, so I put it back on, (yes, routed it properly), and the tension is nice and snug. But still, it jumps. I have both cover mandrells on. I've adopted a process of lifting the deck as high as possible before engaging the drive so as it minimize the likelihood of the belt jumping. (Obviously, the belt is most "in line" with the drive pulley with the deck as high as possible). The belt stays on with the deck up high, but, as soon as I lower the deck, it jumps.
What's strange is that the old, worn, belt was not jumping off. I would have thought, if any deck belt was going to throw itself off it would be an older, worn, ...stretched belt -- not a brand new OEM belt.
I believe the deck's components are in good working order. Spindles, while original, do not have play in them and spin smoothly. Idlers/pulleys seem in good shape - not worn. I will say that one of the cover mandrells had a crack where one of the bolts secured it so it was not TIGHT against the deck. I can't believe that would be the issue. Again, the thing that is strange is that the old belt was not jumping off.
Any ideas? Thank you!
Jay
Jay
