Bran New Cub Cadet ZTX5-54 inch
   / Bran New Cub Cadet ZTX5-54 inch #11
Manual says not to.
The manual also says to remove the mower deck every time you clean it or change blades....:unsure:
   / Bran New Cub Cadet ZTX5-54 inch #12
We will be using Mobil 1 5w30 in the trans axel
I had to google that one a bit. Most hydro/transaxle fluids are more like 20w50, BUT, there's plenty of ~30W specs out there also, should be fine.
You can run whatever tire pressure you dang well please. The ~10-15 psi range is definitely nice and cushy, and gives better traction. Just gotta keep an eye on them so they dont get low/flat and blow off the rim.
   / Bran New Cub Cadet ZTX5-54 inch #13
What does the manual say about tyre pressures ? Manual says do not touch , that surprises me
Generally those rear tyres only run a low pressure 10 to 12 psi on convential Cub mowers , out front might be the same , I would check for sure
   / Bran New Cub Cadet ZTX5-54 inch #14
As far as I can see, my manual does not specify tire pressures for the ZTXS5 54. All it says is check tires and set to "recommended pressure". Since it does not specify the pressures, I can only assume they are referring to the maximum pressure shown on the sidewall.
They probably omit the tire pressure because the manuals cover several different models, all of which have different sized tires/pressures.
I would be interested to know if anyone else's manual actually specifies a tire pressure.
   / Bran New Cub Cadet ZTX5-54 inch #15
The Carlile Turf-masters on my Cub ZT2 mower show both "max 10 psi" and max 2.5bar (=36 psi) on the sidewall in directly conflicting markings. So stupid. I'm running ~12, pretty comfy.
   / Bran New Cub Cadet ZTX5-54 inch #16
Why don't you ring the mower or tyre manufacturer and ask
easy as
   / Bran New Cub Cadet ZTX5-54 inch #17
"For a Kawasaki engine in the Cub Cadet ZTX5 54 zero-turn mower, the recommended engine oil type is 10W-30 SAE Premium 4-Cycle Engine Oil."
I'd prefer Castrol or Valvoline.
Manual says first change at 25 hours then every 100 hours after that. Changing more frequently for extreme use or engine longevity certainly would prolong life as well as keeping a clean air filter on it. I wash the foam pre-filter, dry it and spray a little WD-40 on it. It seems to catch more dust/dirt that way.
You can buy a pre-cleaner oil , better than WD40 , it is quite sticky and definitely traps the dust and debris
   / Bran New Cub Cadet ZTX5-54 inch #18
My manual recommends engine oil on the pre-cleaner if I remember correctly. For exactly that reason - to better trap dust and debris
   / Bran New Cub Cadet ZTX5-54 inch #19
Here is what the engine manual says for the Kawasaki FS730V on the ZTXS5 54 regarding service of the air filter:
26 MAINTENANCE
Foam Element
Clean the foam element (A) every 25 hours.
• Wash the element in detergent and water, and dry
it thoroughly.
Paper Element
Clean the paper element (B) every 100 hours.
• Clean the paper element by tapping gently to re-
move dust. If very dirty, replace the paper element
with a new one.
Replace with a new paper element yearly or 200
hours. Whichever comes first.
NOTE
○Operating in dusty condition may require more fre-
quent maintenance than above.
CAUTION
Do not wash paper element.
Do not oil foam or paper element.
Do not use pressurized air to clean paper el-
ement.
For engine oil, it gives the usual chart with the arrows, showing SAE40, SAE30, 10w-40, 1w-30 and 5w-20 depending on expected ambient temperature.
   / Bran New Cub Cadet ZTX5-54 inch #20
I've blown out the paper element for years and years on all my serviced mowers. Without issue I might add. Does anyone know the reason why they don't recommend blowing out the air filters ? Like mentioned personally I've not had any issues with this method. Even on my Ridgeline I've done this and had an oil analysis done afterwards and it was even mentioned that the silica in the oil was low and the air filter was working well. Anyone know ?
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
New Idea 484 Round Baler (A50774)
New Idea 484 Round...
Paver (A50774)
Paver (A50774)
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
