Brakes Seizing- 1994 Ford NAA
   / Brakes Seizing- 1994 Ford NAA #1
Ortis
Maryland
When I press the right brake pedal on this tractor, or even at times if I don't, the right wheel locks up and does not release until it is dragged along for a while. I'll pull the wheel and look, but has anyone else been through this? Could it be as easy as a missing return spring, or do these get a worse affliction?
   / Brakes Seizing- 1994 Ford NAA #2
It's probably a '1954' NAA..Might just need to adjust the brakes and / or a broke brake spring.
Soundguy
   / Brakes Seizing- 1994 Ford NAA #3
Wow - Iv'e got a 1954 NAA Golden Jubilee TOO.
Someting is broke off in there flopping around - as you say pull the wheel and take a look. Attached is from my shop manual.
   / Brakes Seizing- 1994 Ford NAA #4
Here is Picture 2
   / Brakes Seizing- 1994 Ford NAA #5
Part 3 of the manual
   / Brakes Seizing- 1994 Ford NAA #6
4 th and final info from shop manual
2021 BOBCAT T64 R-SERIES SKID STEER (A51246)
2021 BOBCAT T64...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
UNUSED CFG H15R EXCAVATOR (A51247)
UNUSED CFG H15R...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51247)
GEHL RB1470 TOTAL...
HOBBS MODEL-666 16' HAY RAKE (A51247)
HOBBS MODEL-666...
2017 Nissan Altima (A51694)
2017 Nissan Altima...
