Brakes on Olds Aurora
   / Brakes on Olds Aurora #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I did the rear brakes on my sons 1999 Olds Aurora today. I put on new rotors, and pads. The one thing that was different, is most vehicles I just pushed the piston back into the calipers with a large C clamp and was done. On this car, it took a special tool and you had to spin the piston and push it back into the bore of the calipers. Are the pistons threaded into the bores or what? It seemed like it took about 100 turns to get them back in.
   / Brakes on Olds Aurora #2
It is a design you see with some rear disc brakes. The turning is related to the parking brake. It ratchets out to account for wear. So on those designs you need to push and turn. Depending on how tough it is, sometimes needle nose pliers cna be openeed enough to do the job. But some really need pressure with the turning.
   / Brakes on Olds Aurora #3
my 98 mustang was like that we found out after braking a c clamp
   / Brakes on Olds Aurora #4
It's pretty easy to identify those that require turning, as they will have holes in the face of the piston for the tool.
   / Brakes on Olds Aurora #6
whodat526 said:
my mustang didn't
Oh? How were they designed to be screwed back down?
   / Brakes on Olds Aurora #7
There are actually a lot of cars like this.
   / Brakes on Olds Aurora #8
Theres there are a ton of them out there. A universal tool to screw them back in is very reasonably priced. I've had one for 15 years ... Subaru used to have those on the front disks.
Yeah the tool I bought goes on a 3/8 ratchet, and fits several different style of brakes, it was $11.
   / Brakes on Olds Aurora #10
I just rent the tool or actually they loan it to you at advance for free, you keep it and use it then next time you pass return it for a refund. A lot of those GM cars that size have it.
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
Unused Delta Crash...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
