JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,123
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
After a 7 year break from my post in 2011 regarding MF 2660 brakes (see quote next) I will follow the quote with a question.
QUESTION: Since the above drama, many other bugs were fixed on the tractor and it has become a solid lovable workhorse. [The dealer is long gone, went out of business. Nearest dealer is now 70 miles from the farm, etc.] The brakes work well BUT one side squeaks loudly when any more than light pressure is exerted on the brakes. Essentially all the neighbors know when when I stop going downhill to back up or any time with strong brake application. So the question is: Does this matter? The noise is somewhat cosmetic (and in most ways I don't care so long as there is no serious mechanical concern.) Anyone else out there with this (or other models of Massey with the axle bugles design) have this symptom ? Comments?
After a 7 week delay Massey came up with enough brake discs to convert my 2660 from a 4 disc system to a 5 disk system. The parts people insisted they could not find the discs to do the mod in that period of time (!) Note that these tractors (according to the shop manual) are produced with 3, 4 and 5 disc brakes. That is, wet brakes with that many discs on each side. Notches in the edge of a wafer showing at the rear of the axle indicate how many discs are in there. Most are apparently 4 disc systems (I've never seen anything else at dealers...) . I pity anyone with a 3 disc system ! The problem has utterly nothing to do with adjustment.
I tested the "new" 5 disc configuration on a 50% slope in 4WD with enough traction to stay put. Now it WILL stop the wheels from turning. Previously with a 4 disc system you could not totally stop the wheels from turning on even a 40% slope. In my opinion the pedal force required is still higher than it should be, but at least now a 215lb person CAN stop the thing. I rate them adequate now.
Further to note: Another 2660 was in the same shop for the same modification. Obviously this is a design issue, NOT a single tractor problem. Also, the procedure includes bypassing/defeating the "equalizer" between left and right brakes besides conversion to a 5 disc system.
I'd love to meet the boardroom executive in Massey who decided it was a good idea to put marginal brakes on most of the tractors and then convert them to good brakes in case someone complains ! How on earth do you justify making 3 grades of brakes !?
