brakes on 3015
/ brakes on 3015 #1
pk1mk1
I noticed that the brakes do not hold or for that matter stop the tractor on a hill. When I asked the dealer he said there are three brake positions and I need to hit the brake harder to set it. I can't find more than 1 position.
It seems to me the brake ought to hold or be able to stop the tractor. Am I missing something? What would I do without this site.
/ brakes on 3015 #2
I have a 2015 HST and it has at least two positions or "notches" that I can lock the brakes with when I park it. The first one is pretty easy to set as I don't have to push down on the brake pedals very hard. The tractor will move on a hill with the brakes set on this "notch", however. If I push the brake pedals down with more force I can then lock the brakes on another "notch" and the tractor won't move. Is your 3015 similar?
/ brakes on 3015
Thanks for answering. I found two positions but neither holds on a hill. The dealer said there were three notches but I can't find the third.
/ brakes on 3015 #4
I believe your brakes need adjusting.
Galen LaWall
Your Mahindra Tractor Dealer
Batavia NY 14020
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
2016 Kubota SVL95.2s Skid Steer (A62613)
2016 Kubota...
2014 MACK CXU613 SLEEPER (A65643)
2014 MACK CXU613...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
