Brakes lock up
/ Brakes lock up
Thanks again, JWR! I'll try your ideas.
So I have figured out that it's the left brake pedal that is the issue. And I figured out that if I pull back on the lever that normally serves as a parking brake (although it has not been in use during these incidents), it causes the brake pedal to release. I can't see why.
I called my dealership about that, and they were quite interested, but no one has yet indicated that they understand why it is happening that way. They're still thinking about it.
Do you happen to have any ideas on this?
/ Brakes lock up #12
No, that is puzzling. Might track the linkage from the parking brake lever down underneath and see how it operates. Wouldn't know what else to do.
/ Brakes lock up #13
post pictures underneath the tractor where the pedals and parking brake are. that might help. maybe the parking brake lever is actuating by itself when you press hard on the brakes?.
/ Brakes lock up #14
At least on the larger tractors there is a cable pulled by the lever which activates the regular brakes (by mechanism underneath that I cannot recall details of.) It has a ratchet and stays activated when you pull it up, then releases with a pushbotton on vthe lever that releases the ratchet. You'll just have to inspect the linkage and see how it is connected (or find a shop manual if you can and study that.)
USC Series 2000 Conveyor (A61307)
USC Series 2000...
2012 Toyota Camry Sedan (A59231)
2012 Toyota Camry...
207276 (A52708)
207276 (A52708)
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2012 KENWORTH T800 KILL TRUCK (A60736)
2012 KENWORTH T800...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
