Brakes.... Electric or Hydraulic (surge)
   / Brakes.... Electric or Hydraulic (surge) #1
Al Mac
Canada
Kubota 2920
I am thinking about getting a trailer. It will be a 16 to 18 feet car or deck unit. Something for the older car, tractor, and just hauling anything.
I know if I have one family and close friends will want to use it from time to time. I have no issue with that but if the unit has electric breaks they might not have the break controller in their truck. I would not babysit what they are doing.
With the hydraulic brake trailers they just hook up and go.
I see that electric brake are more popular and most people don't lend their equipment out. Hydraulic brakes are on all the rental units so they must be reliable.
Your Thoughts
Al
   / Brakes.... Electric or Hydraulic (surge) #2
I HATE surge brakes. Many (most?) States and provinces don't allow them any more. They rely 100% on the towing vehicle to be able to slow&stop to apply the braking force while with electric you have control at your fingertips. Sure, the convenience of being able to tow with any suitable vehicle is nice but personally, I don't think the loss of control and adjustability is worth it.
   / Brakes.... Electric or Hydraulic (surge) #3
I absolutely hate surge brakes. Get a good brake controller and don't mess with them. I'm wonder if your trailer is going to be long enough though. Measure your longest load and remember you need some length to adjust the weight distribution.
   / Brakes.... Electric or Hydraulic (surge) #4
Electric brakes all the way! You have way more control over the trailer with the electrics than with surge.
   / Brakes.... Electric or Hydraulic (surge) #6
Electric.
   / Brakes.... Electric or Hydraulic (surge) #8
I have never had electric brakes work on any thing worth a *****. stock trailers, goose necks, and so on, they will work for a few times and in a month they will no longer work, the first time I had real brakes were when I put surge hydraulic brakes on the stock trailer,
I replaced brakes, controllers and other a number of times and on different trucks.
   / Brakes.... Electric or Hydraulic (surge) #9
Surge brakes work great. You pull the trailer with just about any vehicle that can handle the weight. But they are not that great on ice or snow and are a pain to back up the trailer with. Electric brakes require your vehicle to have a brake controller installed, also work great, and are no problem to back up with. The electrics allow you to test and use the trailer brakes any time you want fairly easily. Long term, I started with the surge brakes, but finally converted my trailers over to electric. So, mark me down in the electric column.... :)
[ I put self adjusting backing plate/brake assy's on them, and did a world class job of rewiring ... making sure things would last.... Main north south trailer wiring in conduit and everything tucked up good where it can't get into trouble.. ]
   / Brakes.... Electric or Hydraulic (surge) #10
Ditto what JerryK said.......plus when the surge brakes lock up due to backing etc........it ruins ______another_____ tire.
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2014 Dodge Charger Sedan (A51694)
2014 Dodge Charger...
2003 Great Dane 53 ft. Dry Van Trailer (A53117)
2003 Great Dane 53...
2009 Mazda 3 Sedan (A51694)
2009 Mazda 3 Sedan...
