Snow Brake steering on Snow
/ Brake steering on Snow #21
When ever plowing or bucketing with either my TN or 2120 I steer with the brakes. Bucket float makes no difference. what I am pushing is always off center enough to pull me one wy or the other. The parking lot at my building has enough slope so that I am always sliding downhill. 4WD or 2WD makes no difference, I'd be lost with out usuable split pedals. One bid negative aganst most hydro setups in my opinion.
Andy
/ Brake steering on Snow #22
"One bid negative aganst most hydro setups in my opinion."
I think Kubota's HST is one of the few that has this as an issue, especially if we are talking about the larger compacts. I assume that you are talking about your parking lot at work having snow on it. One negative about living in snow in my opinion besides the cold, oh yeah and that spring thaw. /forums/images/graemlins/grin.gif Of course there are worse things like living on a little city lot.
/ Brake steering on Snow #23
Chains would no dought make a difference. I'd be able to plow up the big hill on our drive easily. Can only take a light pass going up. Last year we had record snows and did ok with out them and on our last snow. I'll probably get a set because just because of all the freezing rains we had this year.
This the start of my second year in the country and its been bang from day one!
/ Brake steering on Snow #24
Currently at our place in Tahoe we have 72" of snow. At the nearby resorts there is over 200". It's funny because I'm only 60 miles away from there and yet once every 5 years we get a drop of snow.
/ Brake steering on Snow #25
</font><font color="blue" class="small">( Make sure your not putting your whole foot on the pedal, )</font>
I've had my foot in every conceivable position on the pedal except for Henro's sidesaddle method /forums/images/graemlins/grin.gif
When I hit a bump or rut my body moves, which translates to my leg moving, which pivots my foot a bit on the heel and moves the HST pedal. I've no doubt it's operator error, but I never had this problem with my B7500. I prefer the operation and location of the pedals on the B7500, especially reverse, but that's just me.
For those that may not know, I haven't seen it mentioned... You can vary the speed on a 3130 (and I'm sure other models) with the cruise lever. It isn't a locking lever/knob that locks the HST pedal in one position like on a B7500.
The cruise lever, which is on the left side of the seat and easy to reach without moving, actually moves the HST pedal. It's very easy to adjust speed with your left hand and work the brakes with your right foot.
/ Brake steering on Snow #26
<font color="orange"> The cruise lever, which is on the left side of the seat and easy to reach without moving, actually moves the HST pedal. It's very easy to adjust speed with your left hand and work the brakes with your right foot. </font>
That sounds interesting. I didn't know Kubota had an adjustable cruise control.
One thing that I wish these companies would do is if they want to use the treadle pedal, why not at least place the brake pedals on the other side so those who use differential braking could use it? The adjustable cruise that Kubota has is ok, but as far as I know most machines don't have an adjustable cruise. If you need to use the differential braking and have to engage the cruise in a tight spot that could make for a dangerous situation.
/ Brake steering on Snow #27
Freds, as little as I use the cruise control, it is remarkably simple and easy to use. I don't know how you could improve on it. In the past I have thought about the brake issue Kubota has with regards to HST. I envision using a electro mechanical means of actuating the pedal via a toggle that would operate the left or right brake. It could have the toggle switch on the joystick
/ Brake steering on Snow #28
It's really no different to use than a hand operated throttle on anything else (snowmobile, ATV...).
I was thinking about Kubota's pedal placement this afternoon and the only reason I could come up with, and it's a stretch, is that they wanted the clutch pedal by itself. Maybe they feel the clutch pedal by itself is more idiot proof if the "feces hits the fan" and you need to get things stopped in a hurry. That or it's a patent thing /forums/images/graemlins/tongue.gif
/ Brake steering on Snow #29
"If you need to use the differential braking and have to engage the cruise in a tight spot that could make for a dangerous situation."
The cruise control instantly is out when you hit the brakes. I think what it boils down to is that if you insist on having differential braking and want HST on top of that, look at NH or JD. Since snow is not a factor for me, or at least not to where I need to move it myself, I have found that even on my NH 2120 and my old International 454, I simply never take advantage of differential braking. Even in our orchard where we make tight turns with a large mower, the turning radius is more then sufficent without having to use differential braking and skid a wheel around the turn.
No, I don't NEED the BH in the winter.. it's more of a space thing.. Keeping it on the Tractor lets me get the BH in the garage over winter too. I know they are built to sit outside.. but I'd rather not worry about rusting of the hydraulic pistons and all. And, in case I do need to use it.. I'm not digging it out of three feet of snow and ice.
as for the 4wd issue.. the whole reason I'm using the rear brakes to turn is that the front tires are lifting off the ground, or at least losing grip to the point that I'm going where I don't want to go. So.. I don't think dragging the front tires is an issue. Next significant snow I'm going to try 2wd.. not sure that will make a difference going uphill and all. PS.. it's only on float that I seem to have this problem.. if I'm running the bucket with the stick I can bring it up a little and the fronts sit down.. unfortunately.. that doesn't help filling the bucket with snow. I keep the lip angled up a bit because I don't want to bite in too much and take too much gravel with the snow..
I may just go back to the blower full time. My Neighbor suggested suitcase weights to help keep the front end down.. when pushing snow. I'm not sure you can use weights with the loader attached.. will have to investigate that.
I would venture to guess from your location that you don't get a lot of experience on snow. Unless you have a load in the bucket, raised up to put the weight on the front wheels.. you can lose grip, especially going uphill. While floating the bucket, the moment you start pushing snow the front tires start to lose grip or even rise up. If you don't float the bucket you don't do a very good job of clearing the snow on uneven terrain as I have here. The weight of the snow that you're pushing and the drive of the rear wheels causes it. Simple physics, not lack of experience. Some of the wet heavy snow we get here has more weight than clay. And when you're trying to plow with the bucket it can dam up in front for several feet providing an equivalent in mass to driving into a pile of gravel. Add the fact that snow is slippery into the equation and you may see what I'm getting into. 4wd may be part of the problem. If you've ever had an SUV in snow and gas it while turning you know you go straight ahead.. the tires spin free and you lose steering.
I grew up around tractors... although this IS my first Kubota and HST.
/ Brake steering on Snow #32
I just did my 750 foot driveway today with my 3130 and played with this.
As in te past I use the cruse and diff braking. No problem at all. The cruse will stay engaged untill you hit both brakes at the same time which then disengages the cruse.
My solution to this is when the snow gets deep, I get out my JD 4020, not much stops it /forums/images/graemlins/grin.gif.
Dane
/ Brake steering on Snow #33
Can someone explain what it means to float the bucket and how it's done. I have a BX23 and basically adjust the bucket as near to the driveway as possible..not sure if I have the abilty to float the FEL on my unit.
/ Brake steering on Snow #34
on most kubotas the valve has the capability of being pushed through the down positon and into a detent mode that holds the valve open. This allows the bucket to follow or float along the ground.
Try pushing your lever past the normal down position, you should feel it "click" into place and stay there until you pull it out.
One word of caution, do not use this position to lower your bucket as it will free fall against the hydralics and hit the ground hard.
Most people put the bucket on the ground and then go into float position. This helps not to tear up your drive way or what ever else you are working on.
I hope that is clear as mud.
Dane
JOHN DEERE 3120 TRACTOR (A64280)
JOHN DEERE 3120...
Pair of Assist Wheels (A64119)
Pair of Assist...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
445 (A63290)
445 (A63290)
(1) UNUSED 12-16.5 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 12-16.5...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
