$10 bucks locally to turn rotors, but I turn my own ( leftover equipment from my dads NAPA shop). I usually mic the thickness and check runout with every pad change, turn if needed. I am the only one that touches my brakes as I trust my skills against what see in the shops nowadays.
I had the brakes worked at the Ford dealer on my F350, I always wear old clothes when I pick up my vehicles as I will get on the ground and crawl under to verify work. Found two caliper bracket bolts missing, after speaking with the manager about safety concerns they ate the bill but said they could no longer work on my truck to which I told him he was correct.
They no longer wanted work on your truck because you are better than the mechanic that worked on your truck and got paid for it.
What's wrong with this service manager. He should be happy he didn't have a law suit on his hand. The get fired.
Garages don't resurface rotors anymore, and haven't for probably 20 years. Their liability is too great, and customers will come back and complain about pulsing brake pedal, (warped rotors), etc., etc.
Brake jobs are expensive, but their are the first line of defense when one needs to stop, and they better work right when you need them.
It cost what it costs, parts, overhead, liability insurance, ASE certified mechanics, etc. I know, I owned and ran a shop.
That's simply not true. Many, many brake rotors are "turned" every day. It totally depends on the application and the damage to the rotors. If they have been heated repeatedly and over a long period of time before repairs are made they may be warped so bad that turning them will result in a thin rotor, not good. But if the owner is taking care of business and maintaining the brake system regularly the rotors can be turned a couple times minimum before they are discarded. Last week I had the rear rotors on my Super Duty turned and new pads installed.
