Brake pedal have a little interference.
   / Brake pedal have a little interference. #1
dshontell
North Georgia
2014 Branson 2400 H
Was looking around the tractor today and found this hydraulic line really in the way of the brake linkage arms. I have not studied it enough yet to see what I can do to get it out of the way. Not sure yet as to what it works with either.
Also found that the brakes must be way out of adjustment. Pedals when separated sit at different levels.
Next day that's nice enough, I'll get under it and see. Lay hands on it.
Dang app won't let me add pictures.
Sent from my brain using TractorByNet
I guess it added the pics anyway.
BTW it's a Branson 2400 H tractor.
   / Brake pedal have a little interference. #3
See if you can take the hose with the 90deg and change end for end. The other end might not have a 90deg.
   / Brake pedal have a little interference. #4
Looks like the zip tie is broken in your photo that hold the hose up.
   / Brake pedal have a little interference. #5
Had the same problem with my 2400H. A couple of minutes with a wrench and the hose was rerouted out of the way. Can't remember if I had to add another zip tie or not.
   / Brake pedal have a little interference. #6
Hmm, I better have a look at mine...
BTW, has anyone else thought about swapping the forward/reverse pedals?
It would be much more comfortable to have the go pedal on the right side (Big Feet!)
Would I be voiding any warranties ?:scratchchin:
   / Brake pedal have a little interference. #7
Never thought about swapping the pedals but suspect it would be a major overhaul of the linkage.
Not sure about the warranty aspect though.
Bajabum
I had the same thought. I am continually tapping reverse. Location location location. And access to the brakes pedals are very awkward in my opinion.
Kinda think they FUBARed this a bit.
   / Brake pedal have a little interference. #9
I was thinking of just swapping hoses.(and rubber pedal pads)
   / Brake pedal have a little interference. #10
No hoses to swap on these. All of the HST tranny lines are internal and the control is all mechanical linkage.
2005 Case 650K Series 2 LGP Crawler Tractor Dozer (A51691)
2005 Case 650K...
Trojan 50CL 40mm Hydraulic Hammer, New  (A52384)
Trojan 50CL 40mm...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
1270 (A50490)
1270 (A50490)
T3 Motion Patroller Segway (A51694)
T3 Motion...
SHOP TOOLS (A53843)
SHOP TOOLS (A53843)
