Brake issues
   / Brake issues #1
Caveman3250
ineedhousewerks@hotmail.com
I posted a question a few days ago about my wet brake issues. I have repaired the brake lines by splicing by brazing a new section into it. After I reassembled the axle assemblies, I filled with brake fluid and it still drained out somewhere. I took off one assembly and noticed that the O-rings around the brake piston/disc was leaking. So I need new O-rings, 2 per side. Checked with Hoyes and they said they don't have them to look locally! Really! Nobody even knows what a Yanmar is around here! Anyhow, do any of you guys know where I can get O-rings for this brake component? Or do you know the specs for the o-rings so I may be able to order some generic ones from this type of vendor.
The tractor is a FX32D btw....
Caveman
Eads TN
   / Brake issues #2
Caveman,
Buying locally = If you go to a shop that sells bearings & seals, you can lay the part on the counter and show them what you want...
I do it all the time:D:D
   / Brake issues
Good idea, think I will try this. I have looked up o-rings online and measured the old ones and am about to order some this way, but I was worried they may not be right type ie: round vs square, slight taper, etc..... Old rings may be worn and not accurate to measure the cross/section.....
Thanks for reply!
Caveman
Truck Wheel Fenders (A51692)
Truck Wheel...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2008 Ford F350 XL, Diesel Dump Bed w/Spreader Box (A52384)
2008 Ford F350 XL...
2016 Ford F-550 Enclosed Service Truck (A51692)
2016 Ford F-550...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
