Brake Controller Reese vs. Prodigy vs. ???
   / Brake Controller Reese vs. Prodigy vs. ??? #61
Brad_Blazer said:
I think I was one of the first posters in this thread to suggest that a timer based controller is not ideal in a panic stop situation. That said, there are many factors that affect the stopping distance of a vehicle and it is simply not practical to always drive in a configuration that minimizes stopping distance (no passengers, low on gas, no cargo, and certainly no trailer). You drive conservatively based on the limitations of your vehicle and keep your rig properly equipped within the law and your means.
So you are the reason for the exchange between Soundguy and me. Thanks for taking the heat! :)
   / Brake Controller Reese vs. Prodigy vs. ??? #62
I guess I should dig my manual out. So are you indicating the Prodigy does not brake in reverse?
I do not tow boats; just my tractor/flatbed, and 5th wheel. Not an issue for me, like a boat on a ramp.
Can you elaborate a little on the electric controlled brake systems for a 15,000lb boat/trailer? How does it work once submerged? Guessing the system is water-proof? Only boats I have towed were little 14' w/outboard, single axle no brakes, some years back(pretty lite weight).
Have you ever towed a trailer with the electric over hydraulic brakes on the trailer? Saw a 5th wheel a couple years ago that had that setup. Guessing the system is water-proof?
No, all I have seen have a manual activation but many of the inertia styles will not allow braking in reverse. This is where the timed and pressure based system. Yes, you can always us the manual feature but I dont want to think about it.
Chris
   / Brake Controller Reese vs. Prodigy vs. ??? #63
First of all, everything I tow except my car haul trailer have DISC Brakes, not drums. I have battled drums for years and now order them with Disc or convert them asap.
The two bigger boats I tow have electric over hydraulic systems with tri axles and 14" disc on all 6 wheels. It will stop that load in a hurry.
I have seen electric drums on boat trailers but they are not common. They work just fine in fresh water. Not so sure about salt water but I never do that anyway so its not a issue. I have backed my 18' car hauler in the drink a few times to haul dock sections out, ect. No issues with the electric brakes.
Chris
   / Brake Controller Reese vs. Prodigy vs. ??? #64
I have the Prodigy and have towed across the U.S. quite a few times, it has never broken or let me down. If it works it works, why switch?
DevilDog
   / Brake Controller Reese vs. Prodigy vs. ??? #65
Sounds like your boat elect/hydro is what I also saw on that 5th wheel; I did not ask if it was drum or disc.
Having disc on all our vehicles now, I could see where that would be nice on the trailer. Not that I could afford it right now, but any idea a ballpark to convert a 2 axle 7500gvrw 5th wheel to disc like you describe?
Chris
   / Brake Controller Reese vs. Prodigy vs. ??? #66
Disc brakes are cheap. I just did a conversion 2 weeks ago to a customers trailer. I used Kodiak Disc Brakes and it was about the same price as overhauling the existing drum brakes. It was $219 per axle for all the parts necessary to totally convert it.
This was for a 12,000# trailer with 2 6K axles. I am sure you could do a 3.5K axle for around $175 or so.
Chris
   / Brake Controller Reese vs. Prodigy vs. ??? #67
To answer your first questions, my prodigy DID work in reverse with the electric brakes on both axles on my boat trailer. The electo-magnets are sealed in epoxy so have no problems being underwater. You must maintain the connections at the wires just as you would on the lighting. My trailer just has drum brakes on two 3500 lb axles. It came from the factory with hydraulic surge brakes I didn't like and converted them to electric. One of the reasons being surge type brakes don't work in reverse going down hill. I welded up the surge points on the tongue a
   / Brake Controller Reese vs. Prodigy vs. ??? #68
Chris
I didn't realize they were that cheap. I am converting my camper into a toy hauler and adding a second axle in the upcoming weeks and will look into this option for the new axle.
   / Brake Controller Reese vs. Prodigy vs. ??? #69
No, it's not. You choose to justify it that way to enable your argument. And just because something is mass marketed and easily available doesn't automatically qualify/disqualify it's existence. Sometimes it just means the topic never got much media notice befor the insurance co. settled.
And having driven umpteen million miles on " good enough" doesn't necessarily substantiate a claim either. Really just implies that fate/karma/God had a hand in the game. Remember the old saying, " god protects drunks and fools".
Um... ok.. we disagree. no problem.
soundguy
   / Brake Controller Reese vs. Prodigy vs. ??? #70
I would not mix and match. If you have drums stay with drums. Same is true for disc.
Chris
2013 Mack GU713 (A60460)
2013 Mack GU713...
WATER TRAILER (A58214)
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
