Brake adjustment ?
   / Brake adjustment ? #1
RickSr
Bronze Member
Mahindra Emax 20s HST
How do you adjust the brakes on a Mahindra emax 20 hst. Thanks in advance.
Rick
   / Brake adjustment ? #2
There is a rod going from the pedal to the back of the tractor. On this rod, you'll find a coupling nut (the longer one) and a jam nut. Loosen the jam nut and then adjust the coupling nut to increase or decrease the length of the rod and therefore adjust the brakes. Get the jam nut tight once you're done with it in the end. You'll want some free play on the brake pedal, like an inch or so.
If you have troubles finding the linkage, get someone on the tractor just pressing and releasing the brake pedal while you check for the linkage underneath.
   / Brake adjustment ? #3
Why do you think adjustment is needed?
I ask as I had an eMax and always thought the brakes were weak. They worked but if I forgot to release the lock the HST would easily overpower them.
I now have a Max26. When those brakes are locked the HST will not move it. BIG difference between the two.
Thanks for your reply.
I think they need adjustment because the peddle seems to be going down much more than when I first got it. The brake works, I think there's just to much play in it.
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
Pallet Fees (A50774)
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
